Canon IRV C3520i keeps restarting
  • Monk
    • Dec 2021
    • 3
    It was on when electricity was cut, and then electricity came back for couple of seconds and was cut again, and then when electricity came back it just reached to the end of the loading where the Image Runner Advanced logo appears and turned off and restarted. Since then it keeps on doing that.
    (details found in this video, it is 5 minutes long because i kept it in real time).
    Any advice would be much appreciated.
    Thank you.
  • Hishamawada
    • 174
    Re: Canon IRV C3520i keeps restarting
    Mainly when the printer fails to startup then its the main controller issue .
    Try removing it and placing it back in its place .
    Sent from my M2101K6I using Tapatalk
      • 8136
      Thank you.
      From your video this looks like you have an issue with the HDD and/or system software.
      I would start formatting the HDD & reloading the software.
      • zoraldinho
        teacher-guide-expert-guru
        • Mar 2008
        • 5007
        I agree
        • Monk
          • Dec 2021
          • 3
          Thank you Copier Tech,
          Can you please share with us the tools needed along with guidelines for formatting the HDD and reloading the software for the machine? Also, would the machine accept a 500 GB HDD instead of the original 380 GB?
          Appreciate your help on this.
          • Hishamawada
            • 174
            End users are not allowed to obtain the firmware for the printer. You should contact a technician to solve your problem .
            • saibajustica
              • Mar 2018
              • 20
              Can't firmware be downloaded from the Canon site? Genuine question.
              Enviado de meu SM-A107M usando o Tapatalk
              • Hishamawada
                • 174
                Ofc not , its only available for canon certified technicians.
                  No.
                  • saibajustica
                    • Mar 2018
                    • 20
                    Thanks [emoji106]. I'm a fresh newbie.
                      • 8136
                      Yes we can supply this for you, drop us an email from the links below.
                      • Monk
                        • Dec 2021
                        • 3
                        IT WORKED. Thank you for the great support... issue solved.
                        Just wondering if you have any idea incase i need to buy a UPS for this copier to avoid issues that relates to electrical shortage, what is your advice regarding the specifications?
                        Thank you again.
                          Thank you again.
                          A line conditioner would be better a Uninterrupted Power Supply could be damaged to the constant drain on it.
                          Hook one up, power up the copier, it starts beeping, that shows you it is draining a LARGE amount of battery each time the fuser draws power to be able to come up to temp.
                            • 8136
                            Thank you again.
                            Glad we were able to help.
                            • Victor H
                              • Aug 2016
                              • 21
                              Hello sir, I have the same problem with IR advance 6565i. Same as the video shows. Can you please help. Thanks
