Canon C5850i damage transfer belt
  • mackon91
    • Jan 2021
    • 6
    In the Canon C5850i device at the 500k pages I replaced the transfer belt along with the transfer cleaner assy, ​after printing 90k pages the belt wore out as in the picture. All materials are original. Replacement in accordance with the service manual procedure. Does anyone have an idea why this happened?
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5015
    ITB cleaning blade is not ok. They have changed the code twice already. Check if you are using the latest one.FM1-R475-20
    • mackon91
      • Jan 2021
      • 6
      I used FM1-R475-010 because I don't have this latest modification available in the official distribution. interesting...
      • zoraldinho
        • Mar 2008
        • 5015
        This blade is also ok. This happens often, which is why a bulletin was published on this topic on 15 Jan 2025.
        • Larhal
          • 584
          Could you share that bulletin with me please?
          Larhal
          If all else fails read the Service Manual!
          If that fails, meet me at the pub and we will discuss it.
          • Londo
            • May 2021
            • 16
            here you go
            • Larhal
              • 584
              Originally posted by Londo
              here you go
              Thank You very much.
              Larhal
              • techandtrader
                • Jun 2016
                • 335
                Also I hear we should be checking transfer roller bearings for resistance. I hear loose toner can cover them and cause the to get sticky. What else is there to know about these units?
                I have used Canon Imagerunner parts for sale. Most are floor model Color and / Advances Imagerunner with some 3025 3235 parts. Several intact machines being parted.
                • techandtrader
                  • Jun 2016
                  • 335
                  • techandtrader
                    • Jun 2016
                    • 335
                    Is AKD / ASD Also known as HP Colorlok ? https://www.colorlok.com/
                    • techandtrader
                      • Jun 2016
                      • 335
                      The latest shipping part is only -010 so there is no -020 yet.
