Settings/registration button not working
  • Reeves
    • Apr 2012
    • 294
    [Misc] Settings/registration button not working
    Hi Techs
    I have a canon advance c3725i failing to login settings but the same settings button when entering service mode it's working but not when I want to access settings have tryed to reset machine to factory reset the problem is still there am able to login administrator and 7654321 okey but still can't get in settings
    What could be the problem
  • GG CANON
    • Oct 2024
    • 23
    I will start updating the software, then calibrate the touch screen
    • bobburnsreb
      • Mar 2015
      • 231
      Have you tried using the Settings and Registration icon on the main menu to see if it works? Scroll over to settings and registration shortcut I think that's the Icon.
      • Reeves
        • Apr 2012
        • 294
        Yes settings/ registration I can't access to go into settings to change IP address settings/registration icon and 123 icon for checking machine counter are not opening
        • copier tech
          • 8136
          So when you tap the 123 bottom of the screen nothing happens ?
          I would try calibrating the screen.
          • bobburnsreb
            • Mar 2015
            • 231
            This Icon is that I was referring to.
            • Reeves
              • Apr 2012
              • 294
              When i press the 123 icon the toner is there and you can see that it's pressed but the machine counter display is not showing
              • Reeves
                • Apr 2012
                • 294
                I ll try tomorrow morning
