Canon ir7105 black background
  • trkder
    • Oct 2022
    • 2
    I would like to ask about a problem am facing in canon ir7105 it was printing good and lately all of a sudden in the morning when i start printing after normal printing 100 pages it prints a full black background page I changed the the transfer, the corona, developer, and even the led on the drum with no luck, it always prints normally for a while then a sudden black page.
    This gallery has 1 photos.
    • 22927
    It looks like wrong toner, to me. Of all the brands that I've worked on, it was usually the Canons that endusers would re-fill the toner cartridge with ... I don't know ... whatever is on hand, and sometimes black ("All toner is the same, right???"). If you look inside the machine, it will look like the toner cartridge exploded. There is only one place the toner doesn't want to be: in the developing unit.
    • copier tech
      • 8100
      Check / clean the drum earth contacts especially if this is a high millage machine.
      • COPIERTEC ASSOCIATES
        • Aug 2011
        • 279
        work around;
        1. this is a drum charger problem on this model, remove the charger assembly and clean the corona wires
        2. under service mode, do the following;COPIER>OPTION>USER>PO and interchange the value of PO.
        If the value of PO IS 0 CHANGE to 1 and enter ok and viceversa ,then SWITCH OFF and ON and make a test copy.
        3. If there is still a background,adjust the corona wires on the drum charger assembly if the problem persists change corona wires.
        4. If the above options fail then change the toner
