Ir 4035i
  • Panhead
    • Mar 2022
    • 4
    [Dead] Ir 4035i
    Hi,I have a machine that the progress bar goes across a third and freezes.It will stay in that condition all day,
    no error codes, unable to access service mode,or he check, replaced hard drive ,reseated cobs,chips,still unable to get in ,
    Any ideas ,main con 1 or 2 . ?
  • Venom
    Technical/IT Support
    • Nov 2009
    • 765
    Re: Ir 4035i
    Were you able to format HDD and load system software?
    IBM, Mita, Konica Minolta, Ricoh, Kyocera, HyPAS, Canon, Oce, Samsung, HP, TEO IP PBX/Unified Communications, Comptia Network+ Comptia PDI+ Certifications
    • Panhead
      • Mar 2022
      • 4
      Re: Ir 4035i
      Unable to get in to hard drive,service mode,hd check,disconnected hard disc got 602 error, otherwise device
      completely dead ,stuck at a third progress bar on display,and stays there.no error codes .
      • kuby
        • Oct 2007
        • 1396
        Re: Ir 4035i
        Did you put in a hard drive from another machine that was the same model and that was working? You know that you can not put in just any hard drive?
        • Venom
          • Nov 2009
          • 765
          Re: Ir 4035i
          did you hold 2 + 8 while turning on?
          • Panhead
            • Mar 2022
            • 4
            Re: Ir 4035i
            I fitted a new sealed canon hard drive as per parts catalogue.fk4 1729.I tried usb and crossover cable, 2 ,8 and 1. 9. No joy ,can not get in to,service mode, or device ,totally froze.
            • Venom
              • Nov 2009
              • 765
              Re: Ir 4035i
              I'm guessing Main Controller 1
              • Panhead
                • Mar 2022
                • 4
                Re: Ir 4035i
                Either 1 or 2 , but unless I find a scrapper, boards are more than the machine is worth! Anyone got a scrapper?
                uk.Thanks.
