Ir6000 Scan button is broken.
  • MisterInvoker
    • Mar 2022
    • 1
    Hello, I'm a Canon Ir6000 user, the Scan function button is not working. Is there another way to access this function? Ui Panel? Touch Panel?
  • wcanonw
    • Aug 2014
    • 404
    Re: Ir6000 Scan button is broken.
    Originally posted by MisterInvoker
    [ATTACH=CONFIG]52689[/ATTACH]
    Hello, there is no other way.
    replace the push button or change another control panel
      • 22996
      Back in the old days we used to de-solder a donor push switch from another location (or a donor panel), and solder it onto the operation panel in your machine. It's been a long time since I looked at one of those machines, so I don't know exactly what kind of switches are used. I believe that I still have a pretty good selection of operation panel push switches. Do you have a photo of the PWB? =^..^=
      • tsbservice
        Field tech
        • 7963
        Agree with BC. We used to do that in a pinch on Toshibas - to name it analog 1550 when interrupt switch was usually sacrificed. That said if plastic button itself is brokean that's another deal.
        • copier tech
          • 8131
          Not seen an IR 6000 in years. What's the counter on!?
          Good machine.
          Yes try & resolder the scan button.
          โ€‹
