Canon imageRunner 4545i Paper Jam Problems
  • riti03
    • May 2022
    • 1
    Hello Guys!
    I have a problem with my Canon copier. I have the jam error "0100A4" which is a jam by the feeder. The problem is that theres no paper stuck. I tried to clean it but the error is still here. Does anybody can help me to solve this problem?
    On Service Mode there was the JamType: POWER ON and the SensorNo. PS_A6.
    Thanky you!
    Best Regards
    Richard
  • Venom
    Technical/IT Support
    • Nov 2009
    • 765
    Re: Canon imageRunner 4545i Paper Jam Problems
    Try pushing a piece of cardstock through the feeder to clear any obstructions. Other then that, you need a tech.
    IBM, Mita, Konica Minolta, Ricoh, Kyocera, HyPAS, Canon, Oce, Samsung, HP, TEO IP PBX/Unified Communications, Comptia Network+ Comptia PDI+ Certifications
    • giogi
      Engineer senior
      • Jan 2016
      • 181
      Try disassembling the sensor and cleaning the sensor surface well.
      Sometimes surfaces are matted
      Normally in the service modes SITUATION>SENSOR CHECK>SP_DADF-A1>P-SENSOR>PS_A6 is a L status
      please check it
      "Knowledge is a source, but unfortunately ignorance is a sea."
      • Andyboachie
        • 185
        Originally posted by riti03
        Hello Guys!
        Thanky you!
        Best Regards
        Richard
        Unless a problem with the DC board, I would check the seating position of the sensor, connector to the sensor, any foreign material that may cheat on the sensor, a disengaged spring. Physically inspect further to find out.
        • bobburnsreb
          • Mar 2015
          • 233
          Solution :
          Clean PS-A6 and add an extra wrap to the spring on the sensor actuator for PS-A6. Parts catalog Fig. B12B #26
