Canon IRADV C5250 Hard Drive
  • RHodg57
    • Dec 2013
    • 191
    I have a hard drive failure on a Adv C5250 so I am replacing the drive. I have the system software
    but I do not have the Hard Drive Format File. I can't get it from Canon. Is there another source I
    can turn to?
  • bobburnsreb
    • Mar 2015
    • 233
    Re: Canon IRADV C5250 Hard Drive
    Sent to you. Good Luck!
    • andinoag
      • Dec 2022
      • 6
      Hi Friends,,, can you guys help me with this firmware and the SST.
      My machine has bad HD and now i need put this working again.
      i appreciate your help
      Thank You!
      • garpit
        Nothing~
        • Mar 2022
        • 10
        Thank You!
        here you can download firmware : Link
        • ADV COPIER
          Pemain
          • Nov 2022
          • 256
          Let's Drink our Coffee
          WhatsApp +62895325228383
          • andinoag
            • Dec 2022
            • 6
            Thank you Garpit.
            I downloaded but still the same error.
            • garpit
              Nothing~
              • Mar 2022
              • 10
              Thank you Garpit.
              what kind of error? i don't have third eye to see your error from here .
              give more detail information what you got there .
              • andinoag
                • Dec 2022
                • 6
                Sorry @garpit... I mentioned it on another post 👇🏻
                I have a problem with file iAC5255-XXxx0671-HDFormat.ift
                When I try to format HDD the display show up the message:
                ////Hard disk format///
                ///Formating HDD. Do not out power.///
                [ERROR]. Cannot read the format file
                Formating HDD(ALL) ... Error
                Hdd format ... Error
                Remove USB device them shut down.
                --- Please hit Reset key to start shut down. ---
                I thought the .ift is bad.
                Thank you 👍🏻
                • Canuck
                  Tech Specialist
                  • 1713
                  Is it a Canon hard drive(Fk4-1550) or one repaired from approved Canon repair? If not, it won't work. And SST is the difficult(archaic)way to do it...get the "USB file" version of firmware and install it in download mode
                  • garpit
                    Nothing~
                    • Mar 2022
                    • 10
                    Thank you 👍🏻
                    its not the SST/Firmware/.ift is bad .
                    if you use original HDD from canon, then its already dead . buy new one .
                    the Firmware wont run except you use HDD type in the list on the firmware .
                    if you want to use firmware and format hdd, use one of this kind hdd type:
                    - Toshiba MK1676GSX
                    - Toshiba MK16GSX
                    - Toshiba MQ01ABF032
                    - Toshiba Laptop Thin HDD (not Momentus Thin)
                    - Hitachi 5K320-160
                    - Hitachi Z5K320-160
                    - Western Digital WD-1600BUCT
                    - Western Digital WD-1600BEVT
                    IMG-20200324-WA0003.jpg IMG-20200324-WA0002.jpg 20191101_120519.jpg 20191113_120014.jpg 20200211_145657.jpg 20200319_152529.jpg 20200326_215618.jpg 20191028_204030.jpg
                    • Canuck
                      Tech Specialist
                      • 1713
                      Don't waste your time and money getting a different drive unless its a Canon drive or one from approved dealer. They are encrypted. Older model copiers could use other drives if you modded ift file. Cannot do it for a 5250 HDD.....
                      • garpit
                        Nothing~
                        • Mar 2022
                        • 10
                        HDFormat.ift is encrypted and can't be modifed .
                        the HDFormat.ift only will run if you use hdd model allowed on that script, just buy some model in my previous post, it will can be used on all x2xx machine .
                        usually i got second hand of HDD from computer store for $15 and can be used normally.
                        if your wallet have no limit, just go to canon or authorize dealer, and ask them new drive .
                        • Canuck
                          Tech Specialist
                          • 1713
                          LMAO....
                          • copier tech
                            • 8144
                            Actually you don't need to get the HDD from Canon. Simply replace with an identical one which you can purchase anywhere.
                            The HDD is only encrypted after it has been formatted & the system software installed.
