New HDD in IR ADV C5051
  • bret@cos.flag.org
    • Jun 2020
    • 98
    Hi All,
    This is a very similar question to https://www.copytechnet.com/forums/c...l-new-hdd.html and I have read through that thread in full, yet I don't think that answers this question - or maybe it did if it were 2013, but here we are in 2022!
    I have a IR ADV C5051 which worked totally fine, but the HDD was removed as the location of it changed hands and the HDD was kept with the previous users.
    I have firmware for these machines and I was able to use that firmware file to update the firmware a couple of years ago, and I have a blank normal HDD, not from Canon.
    The thread from 2013 said that I have to have a HDD from Canon. It also said I can format the HDD but I have to use SST. It also said I can do all of the above with a USB flash drive with the right software. Could it be that I just need to put the firmware files on a USB stick and use the 2, 8 buttons at boot-up and install the software/firmware? Seems too easy. But if so I'll take it!
    Any advice would be appreciated.
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5012
    Re: New HDD in IR ADV C5051
    Work only with Canon HDD for advance series
    20xx
    30xx
    40xx
    50xx
      • 8144
      Originally posted by bret@cos.flag.org
      Hi All,
      This is a very similar question to iR ADV C5051 - Install a new HDD and I have read through that thread in full, yet I don't think that answers this question - or maybe it did if it were 2013, but here we are in 2022!
      • bret@cos.flag.org
        • Jun 2020
        • 98
        Thanks for the responses!
        I got this to work by:
        Using a random HDD that I had. I know it was not the same size as the one that was previously in there, but the label looked to be similar so I think it was the same brand. (I don't have the old one anymore to really compare.) Luckily I had a couple HDDs on hand and one of them worked!
        As suggested by CopierTech, I used a properly set up pen drive, which I set up using SST, and it worked by holding 2 and 8 at boot up, with the pen drive inserted. I just followed the prompts on the screen. I was able to format the drive, and then after a reboot, I installed the latest firmware/software using what was on the pen drive.
        Now up and running again with my new (repurposed) HDD!
        • ed2022
          • Oct 2022
          • 3
          My C5051 has a bad hard drive. The original hard drive is WD Scorpio Blue WD800BEVT-22ZCT0. Can I use a WD800BEVT-75ZCT2? Thanks
            • 8144
            Yes I would say that drive should be fine. Go ahead & try.
            • ed2022
              • Oct 2022
              • 3
              Thank you for replying. I will give it a try. Thanks
              • ed2022
                • Oct 2022
                • 3
                Got this drive. No luck. When format the drive by holding 2 + 8, then 4, 0, I got the hdd format error immediately. Is it another way to format the drive?
                When I format the original drive, it would start (see the ...... on the screen), after three rows of dots, I got the hdd format error.
                Does it mean I have to use a Canon hard drive? or something wrong with this machine?
                Try not wasting more money if the machine is broken. Thanks
                  • 8144
                  The HDD format will fail if the drive is not one Canon on the approved list.
                  I would simply obtain an identical type as the old one. You don't actually have to buy it from Canon.
                  • bret@cos.flag.org
                    • Jun 2020
                    • 98
                    I suppose I just got lucky when I used an apparently "random" HDD and it worked for me.
                    One other thing to consider: is the HDD good at all? Meaning if you connect it to a computer (either using a USB to SATA converter, or connecting it to the SATA cables of the computer's motherboard) does it recognize the hard drive? Possibly you just have a bad hard drive? Wouldn't want to get rid of a working copier just because a HDD is not working at all.
                    Those are my thoughts in case they help.
