Canon IR Adv 5030 weird paper autosizing in ADF
  • Al Shahd
    • Jun 2022
    • 15
    Good day!
    First time I encounter this problem whenever the client scan or copy an A4r size paper or B5 in adf its copied or scan automatically into A3.
    I checked in simulation if adf sensors are working properly all of then are showing up and running good.
    is there any possible reason why is this suddenly occur? Today I'm bringing one working whole adf unit from our workshop but just want to know the main reason of this problem.
    Any inputs will be highly appreciated.
    Thank you
  • bobburnsreb
    • Mar 2015
    • 233
    Re: Canon IR Adv 5030 weird paper autosizing in ADF
    First check service mode level 1 and ensure that MODEL-SZ is set (COPIER>OPTION>FUNC-SW), and in level 2 ensure that SENS-CNF is set (COPIER>OPTION>FUNC-SW). Hope this helps.
    • Uniquer
      • Feb 2022
      • 30
      Originally posted by Al Shahd
      Good day!
      Thank you
      Enter service mode by press service key then 2 and 8 then service
      Go to feeder then adjust
      Then minimize feeder paper guides to the smallest and from screen select a5r size then it will give you ok
      Then maximize feeder paper guides to the maximum and on the screen select a4 size and it will give you ok
      Then it should work perfectly
