Laggy machine canon 6055
  • Uniquer
    • Feb 2022
    • 30
    I have a Canon 6055 which when i pull power button on it take a while to give load screen then it work.
    I suspected the hdd , I have another hdd with firmware ,if I do swap it will work directly or I should download software though
    Thanks for your support
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5007
    Re: Laggy machine canon 6055
    1. You replace the hdd
    2. Format the hdd in download mode
    3. Install new firmware
    If the hdd is not from the same generation same PN) it will not work.
    I would first reload the firmware before changing it.
    • wassem
      • Aug 2012
      • 166
      i think it is a power supply error
      • copier tech
        • 8131
        Yes I too would suspect the HDD.
        As others have said if its from the same generation then try a straight swap, if you get an E602 - xxxx error format the HDD in the SST & reload the system software.
        • Uniquer
          • Feb 2022
          • 30
          Unfortunately, I replaced HDD with another one from a working machine, it worked directly but the same problem.I suspect now the controller but power supply is excluded idea I think.
          • copier tech
            • 8131
            Is it just the panel running slow? The IRA C20/22 series had the sane issue caused by the control panel CPU.
            • Uniquer
              • Feb 2022
              • 30
              When i power it up the power led only light up but nothing on screen for about 5 minutes then loading screen comes up and works normally then.
              • Canuck
                Tech Specialist
                • 1713
                Reseat RAM,etc on controllers for a start. Usually it's a HDD or RAM issue when they are lazy Try a new HDD if reseating pcbs/RAM , formatting, flashing HDD,RAM/controller clearings, initialize all data,etc don't help it..6000s have been around for a while and a used HDD might act similar. I get drives from Nationwide. RAM could be "flakey"(lol) too
                • Uniquer
                  • Feb 2022
                  • 30
                  Thanks for reply
                  I replaced hdd with the same issue
                  Do all types of clears in the function mode and intialized hdd but nothing working.
                  I cleaned both rams but the same problem.
                  What i do fear is if i bought controller may be the problem be from power supply. I dont know
                  • Venom
                    Technical/IT Support
                    • Nov 2009
                    • 765
                    Sounds like main controller is bad
                    IBM, Mita, Konica Minolta, Ricoh, Kyocera, HyPAS, Canon, Oce, Samsung, HP, TEO IP PBX/Unified Communications, Comptia Network+ Comptia PDI+ Certifications
