Canon ira-c 55XX defaults set up sheet location?
  • wachman
    • Apr 2014
    • 50
    [Misc] Canon ira-c 55XX defaults set up sheet location?
    on the 52xx series there is a set up sheet that has defaults just inside the main door.
    Where is this set up sheet now? have new drive installed and working now toner is fading.
    Any help is appreciated!
  • bobburnsreb
    • Mar 2015
    • 231
    Re: Canon ira-c 55XX defaults set up sheet location?
    DCON is inside front cover and RCON is inside reader front cover.
    • wachman
      • Apr 2014
      • 50
      Thank you!! I did find it in the front cover but did not find rcon
      • bobburnsreb
        • Mar 2015
        • 231
        See attached
        • wachman
          • Apr 2014
          • 50
          Excellent totally got it now!
          Thank you for your help
          • Venom
            Technical/IT Support
            • Nov 2009
            • 765
            New HDD wouldn't require factory defaults to be input...you must have done something else to it
            IBM, Mita, Konica Minolta, Ricoh, Kyocera, HyPAS, Canon, Oce, Samsung, HP, TEO IP PBX/Unified Communications, Comptia Network+ Comptia PDI+ Certifications
            • wachman
              • Apr 2014
              • 50
              You are correct. Once I was onsite the user was comparing the image from the old copier that printed their logo on an envelope ant it was lighter that the old copier. I showed her where to play with the density adjustment in her driver and low and behold the issue was fixed.
              I assumed that things changed with the new drive. but I was wrong it was still stored. I verified with the Dcon and Rcon Stickers any way and made a few minor changes back to default. In the end my question was answered, and I am so happy to be a contributor to this site!
