Canon IR1022 - No image, drum covered in toner
  • Mroq
    • Aug 2022
    • 19
    Hello all!
    I am a hobbyist printer technician, looking for advices from other people who might have more experience with Canon machines
    Not so long ago I became an owner of this antique with only 60k clicks on the counters. Printer was run in a corporation thus always on genuine toner and imagining assembly.
    Label says that last developer change was done on 45k, then printer was mostly used as a backup machine run occasionally - still on genuine consumables.
    The problem I have been having with it is a very light print. Some people states that when a drum is not used for a long time it might take a few (or hundreds) pages to recover.
    Unfortunately in my situation it did not done the trick, thus made a decision to clean a developer.
    After that procedure it works even worse - there is no image put on a paper and the drum is always covered in a hard to clean layer of toner powder.
    Drum is really tough to clean with a cloth, it is almost like a both toner and a drum were magnetized correctly but either laser does not work or something is doing a short circuit.
    Secondary transfer roller is also pretty much covered in a layer of toner.
    I have already checked all electrical connections. Protective coating on a drum on the right is worn out, but still does not conduct electricity so it is "alright".
    Laser was removed for cleaning, looks okay.
    Can it be a faulty PCR? Light print, then this?
  • GIUBOSS
    • 1385
    Re: Canon IR1022 - No image, drum covered in toner
    replace the entire drum, you will notice wear and will not be restored by cleaning.
    • Mroq
      • Aug 2022
      • 19
      Hey, I am trying to source somewhere locally a compatible drum unit.
      But still I wonder. I have seen exact same effect on LaserJet once with a new drum. It is almost like some component is shorting out with other.
      I am very curious how exactly the laser works. So we have a drum that is fully charged (negative) by a PCR and a magnetic roller that charges the toner same way (negative). That makes toner not stick to unexposed areas.
      How should the drum look like when laser is not working? Should it be all covered in toner or should it has no toner sticking whatsoever?
      Looking at the picture below it looks like laser beam discharge(?) a part of a drum where a toner must to stick. After the picture is developed a DC or AC charge (do not remember which) "resets" charge on the drum in order to remove any remaining charge.
      I have some experience in re-manufacturing toner cassettes but I am not that good in theory. Is it possible for PCR to have damage in the coating so bad that it basically shorts out the drum?
      • Uniquer
        • Feb 2022
        • 30
        Originally posted by Mroq
        [ATTACH=CONFIG]55125[/ATTACH]
        Hello all!
        [ATTACH=CONFIG]55126[/ATTACH]
        Mostly it is the laser
        Pull out the drum unit
        A lever is pressed by drum to open the laser cover,open it with your hands and clean the glass
        It should work
        • Mroq
          • Aug 2022
          • 19
          It should work
          No luck - Laser is clean. I even removed temporarily that safety shutter just to be sure that it is not blocking anything.
          Two last things to check: PCR and OPC
          • bobburnsreb
            • Mar 2015
            • 229
            replace the drum unit
            • Uniquer
              • Feb 2022
              • 30
              It may be toner type is not okay,check transfer roller is in its place.
              You may attach a picture to see more obviously the problem
              • Mroq
                • Aug 2022
                • 19
                Hello all!
                Many thanks for all the replies.
                I have managed to borrow a different complete drum unit from a local copier technician. Unfortunately the problem is still relevant, thus a faulty developer assembly.
                Those are next to impossible to obtain nowadays so before any pricey commitment I will try to dismount and mount whole developer unit again using service manual.
                There is a tiny (but yet is) possibility that I did something wrong when reassembling developer last time.
                I will update this thread when I will have any new result.
                • GIUBOSS
                  • 1385
                  Hello all!
                  most likely a metal plate out of position, the magnetic roller must be cleaned well but gently and the lumpy or excess toner must be vacuumed. Hope oem toner.
                  • Mroq
                    • Aug 2022
                    • 19
                    Okay so an update to this never ending story:
                    I have some stupid feeling that it was never a developer fault but a HV or something else!
                    By a shear fluke I was able to buy presumably working IR1018i with bad firmware "download standby" error.
                    Both drum and developer assembly from IR1018i looks fine, put into IR1022. A problem with drum fully covered in toner has disappeared.
                    Text is now printed but huge shading occurs on both drum units like on the picture.
                    Any ideas?
                    Should I put developer and drum unit back to IR1018i and just put working main PCB from IR1022 into it? Should be working fine but lacking a few features. At least it could show me if that is a HV problem or should I just scrap both machines...
                    EDIT: How much toner should go to waste toner? Isn't it around 5-10% of toner used for a print? I ran like about 20-30 pages through it and a slit in waste toner container was pretty clogged up!
                    • Mroq
                      • Aug 2022
                      • 19
                      WHAT THE ACTUAL ... HELL IS GOING ON IN MY HOUSE?!
                      So I could not sleep and went back to garage. I did found a firmware for IR 1000 series and put IR1018 back together.
                      This machine has 395k clicks! Can you believe that? Never the less, was serviced till pandemic hit and a business had to close itself. Machine had a full service just before it was "disposed". Looking at drum and it's wiper blade (how soft it still is) and a developer, I could argue if it had more than 1-2k pages done.
                      I have two drum units:
                      - genuine from IR1022 with quite a wear on it
                      - some replacement rubbish from China
                      I have tried to do a single copy from a scanner. Default settings and such. Same result! ON BOTH MACHINES
                      So I swapped drums around and pulled them out mid print to see what's happening. Look at the pictures below.
                      I have tried to wipe some personal data out (second picture) with a clean cloth and the toner was pretty stuck to a drum - almost felt like baked on it
                      Honestly, I am starting to lose my mind over this thing.
                      Toner based the results are the same
                      - IR1022 has genuine toner
                      - IR1018 has after market toner
                      Would it sound stupid if I ask that it might be electric problem? Like a problem with power grounding in my garage? Two very different machines, two drums/developers combinations, two different toners.
                      The only single thing I did not tried yet is to put IR1022 "faulty" developer into IR1018...
                      • Mroq
                        • Aug 2022
                        • 19
                        Nope it ain't it. Tried with different power outlet, as stupid as this idea was no changes.
                        Right now I "scrapped" IR1022 and working on IR1018. This is how test print from service menu looks like on IR1018 in original configuration.
                        Notice that white strip in the middle of the page. By a curiosity I disconnected PCR connection on both drum units with electrical tape.
                        That should give me a 100% black print (or drum coverage).
                        This is something! I might be incorrect here but I think that either toner is about to end or developer blade is getting worn. This is not the problem here. The thing I do not understand is when we take a picture of drum developed with text and a drum that apparently is developed with 100% black it is almost like a negative image.
                        I mean... If there is no tonner in the middle of developer assembly why then it covers entire text when PCR is enabled? Should not be there a white strip in both scenarios?
                        • techandtrader
                          • Jun 2016
                          • 330
                          that drum unit is cooked. you can tell by the offwhite stripe down the side. Also looks like the wrong toner like someone took toner from an HP or brother and transferred it into the Canon.
                          I have used Canon Imagerunner parts for sale. Most are floor model Color and / Advances Imagerunner with some 3025 3235 parts. Several intact machines being parted.
