Ir advc3330 print image dirty
  • kstan268
    • Apr 2012
    • 85
    I need help from all canon big bro...Just now my customer send me a picture said his Ir advc3330 with printing image problem.need help.....dirty print 3330.jpgdirty print 3330.jpg
  • GIUBOSS
    • 1436
    Re: Ir advc3330 print image dirty
    Originally posted by kstan268
    I need help from all canon big bro...Just now my customer send me a picture said his Ir advc3330 with printing image problem.need help.....[ATTACH=CONFIG]56592[/ATTACH][ATTACH=CONFIG]56592[/ATTACH]
    Could be caused by paper stuck in the transfer cleaning unit or even a damaged fuser, do you have any information available on consumables?
    • kstan268
      • Apr 2012
      • 85
      Replace a original Black drum only .I will try to replace a ITB cleaning assy
      • wcanonw
        • Aug 2014
        • 404
        it seems black color problem, first check the black developer, and see if the black toner is original.
        in all the impressions this problem appears or only in the first impressions - copies
        • wcanonw
          • Aug 2014
          • 404
          also check the yellow drum
          • THUK
            • Jul 2008
            • 195
            Could be a fuser issue
            • kstan268
              • Apr 2012
              • 85
              Already settle there is a melt sponge stick on the ITB belt ..and the black dot is fuser assy problem ..scracth
