Canon IR 3300 Continous Restarting
  • princepriyu
    • Jul 2025
    [Electrical] Canon IR 3300 Continous Restarting
    Hello Friends
    i am using Canon IR 3300 photocopier past 9 years,
    since some days i am facing a problem, after starting the machine after some time it reboots itself.
    even while i start the machine sometimes it acts same, continuous reboots, as if i am turning the power off and on
    i hope you have understood my problem
    can anyone help me in this matter
  • kuby
    • Oct 2007
    • 1405
    Re: Canon IR 3300 Continous Restarting
    Sounds like the hard drive is going out.
    • copier tech
      • 8144
      Originally posted by princepriyu
      Hello Friends
      When the device restarts do you have a message on the screen?
      Try updating / re-writing the system software.
      • princepriyu
        Thanks for your reply
        it just restarts, no message or error code or any display on the screen
        even some times machine is on state showing the info but it is gets restarted but the display shows ON ready to operate
        i'l try to shoot a video for better explanation
        any way
        thanks a lot
        • techandtrader
          • Jun 2016
          • 332
          Its the Power Supply. Some of these machine got defective power supplys that were very sensitive to line noise. You can try a line conditioner but praying and changing the PSU is going to be the best.
          Dealers who were good got new PSUs from Canon if they were paying attention and asked for them.
          I have used Canon Imagerunner parts for sale. Most are floor model Color and / Advances Imagerunner with some 3025 3235 parts. Several intact machines being parted.
          • ADV COPIER
            Pemain
            • Nov 2022
            • 256
            Hello Friends
            sound like PSU or Mainboard
            Let's Drink our Coffee
            WhatsApp +62895325228383
            • COPIERTEC ASSOCIATES
              • Aug 2011
              • 279
              Hello Friends
              I met this problem a number of times and the solution to this would be changing the power supply board or the RAM and the problem could be solved.
              Since these are old machines,the power supply always get dry joints or the RAM wears off
              • Canuck
                Tech Specialist
                • 1713
                Update the firmware for starters. Pull the boot ROM and any RAM out and clean the contacts with fine sandpaper and alcohol for starters...I've had it on this series(22/38/3300). Reseat Main con connectors,etc. If still having issues and hard drive is older, replace it.
