Canon IR 5255i ADF copy and Scan pages are black ​
  • Porhuor
    • Feb 2023
    • 30
    Hello,
    I have a problem with canon ADV 5255i with ADF copy and scan. This machine didn't show any error code about ADF. While coping or scanning the front side scanner lamp not light up but the scanner lamp back side is working. When I tried to copy or scan thru the mirror the front side scanner lamp is light up as normal.
    If you have any solution for this problem, Please kindly help!
    Thanks in advance.
    Scanning Doc.pdf
  • copier tech
    • 8172
    Re: Canon IR 5255i ADF copy and Scan pages are black ​
    Originally posted by Porhuor
    Hello,
    Thanks in advance.
    [ATTACH]58694[/ATTACH]
    [ATTACH=CONFIG]58695[/ATTACH]
    [ATTACH=CONFIG]58696[/ATTACH][ATTACH=CONFIG]58697[/ATTACH]
    Have you recently replaced the ADF?
    I would also update the system software.
    • Porhuor
      • Feb 2023
      • 30
      yes, Which system software need to update ?
      • copier tech
        • 8172
        The latest system software / RCON / Document feeder etc.
        • Porhuor
          • Feb 2023
          • 30
          Is there related with function in Service Mode? due to when I clear RCON/DC/SRAMDATA the lamp was light up as normal, but when turn off and turn on power it doesn't light up.
          Does the update firmware are content with those items ?
          • copier tech
            • 8172
            Hi,
            Yes updating the firmware will update those items.
            • Porhuor
              • Feb 2023
              • 30
              Hi,
              Hello,
              After upgrading firmware, ADF copy still black.
              • campy
                • May 2012
                • 315
                The first picture looks like the feeder is up too high on the left. Maybe check the sensor that tells the machine the top is down.
                • wcanonw
                  • Aug 2014
                  • 404
                  [QUOTE=campy;2428740]
                  • wcanonw
                    • Aug 2014
                    • 404
                    the problem could be caused by one of the controller cards of the reader or the dadf
                    • wassem
                      • Aug 2012
                      • 166
                      make sure the glass filter is intalled correctly
                      • Porhuor
                        • Feb 2023
                        • 30
                        [QUOTE=wcanonw;2429380]Thank you for your comment.
                        The problem from the first (Copying glass). but when scanning directly to a copying glass the copy glass works as normal.
                        But scanning from ADF copying glass not light up that cause black.
                        • Porhuor
                          • Feb 2023
                          • 30
                          The machine didn't show any error code about reader unit or ADF but I try to reader board but still have the same problem.photo_2023-08-17_18-12-00.jpg
                          • wcanonw
                            • Aug 2014
                            • 404
                            Reader controller pcb assembly
                            scanner unit, adf
                            scanner unit, reader
                            flexible flat cable unit
                            flexible flat cable guide unit
                            • Porhuor
                              • Feb 2023
                              • 30
                              scanner unit, adf
                              Does it related with service mode function or not?
