Canon C5560i lll document feeder registration problems
  • acsolutions
    • Jun 2010
    • 519
    [Misc] Canon C5560i lll document feeder registration problems
    Hello, registration off about 10mm in feed direction.
    Cleaned roller and dusted off sensors to start with
    Then adjust doc stop in service mode to correct.
    When I place 1 sheet in feeder it's fine also making multiple
    Copies with a single is fine but when I place multiple sheets
    In feeder it shifts again from the first sheet to the last sheet.
    not as bad but comes close
    To cutting off image. Rollers are new and the registration
    Is consistent Thanks
  • GIUBOSS
    • 1436
    Re: Canon C5560i lll document feeder registration problems
    Are you copying single-sided or double-sided? Have you checked the pm counter of the rollers and separation pads, have you seen any jam codes in the log. It could be a sticky absorber on a magnet.
