How to turn Canon iR2520 to a wireless printer
  • Hejsan
    Uhu
    • Mar 2008
    • 42
    Hello everyone...
    My iR2520 printer has RJ-45 and USB ports only. Can I turn this printer to a wireless one? Is there any Wi-Fi card, or something like a JetDirect device for Canon printers?
    Thank you in advance for your kind suggestions...
    David
  • GIUBOSS
    • 1436
    Re: How to turn Canon iR2520 to a wireless printer
    How would you like to print? From PC or smartphone?
    • Hejsan
      Uhu
      • Mar 2008
      • 42
      Thanks a lot for your reply. The printer is located in the office, where we cant put any ethernet cables from the router/switch to the printer. We are going to print from PCs only. Wi-Fi in this office is already installed and works fine
      • KenB
        Geek Extraordinaire
        • Dec 2007
        • 3944
        All you need would be a wireless range extender placed near the machine and connected with one Ethernet cable.
        They pretty much all have either 2 or 4 ports available.
        All for about $50, at least in the US. No need to buy a more expensive one in this case, unless you’re looking to beef up your wireless range.
        That’s how I connected my Brother printer at home. It took about 20 minutes to set up.
        • Hejsan
          Uhu
          • Mar 2008
          • 42
          Thanks so much! I was looking for the similar solutions and found IOGEAR Ethernet to WiFi GWU637 device on eBay for $25 (used one). I will try it... Hope, it works.
          Thanks again for your kind help!
          • Hejsan
            Uhu
            • Mar 2008
            • 42
            Originally posted by terramobil
            We use the TP-Link TL-WR802N N300 WLAN Nano Router. It is easy to configure via smartphone and it will get the power from the USB Port of the machine.
            It's about $ 30 at amazon.com.
            Thanks for the info... I will try that one as well. Let's see, which device will perform better...
            • KenB
              Geek Extraordinaire
              • Dec 2007
              • 3944
              You are quite welcome!
