Canon PC-745
  • bbenson40@yahoo.com
    • Jan 2020
    • 19
    Canon PC-745
    Hello,
    I am working on an Canon PC-745 copier. The machine picks up the paper. It comes into the machine and jams and shuts off the machine. When turning it back on it shows a jam. Any ideas on this one?
    Thanks,
    BB
  • GIUBOSS
    • 1436
    Re: Canon PC-745
    I don't know how cheap it can be fixed, probably a bad or shorted power supply or high voltage board.
    Could you at least check if the corona wires are ok
    • copydocinc
      • Mar 2015
      • 263
      Re: Canon PC-745
      The power shouldn't turn off from a jam unless a door was opened by pressure from the paper doing its U turn.
      Try feeding just 1 paper through the hand feeder on the lower right side of the machine and/or watch to see if
      the little door on the right side of the machine pops open just a smidge while it's feeding the paper out of the drawer.
      There are 2 springs that hold that little door closed and if one of them or both are broken off it will jam. You gotta put the springs back on to a spot that's not broken on the door. Just a little drill hole will hold it.
        Re: Canon PC-745
        had that happen quite a few times. always carried a drill bit in my case.
          • Jan 2020
          • 19
          Re: Canon PC-745
          Hello,
          Thank you for the advice. I have feed the paper through the manual tray it jammed at the first sensor flag. It turned the machine off. I check both spring on the flap door and they are strongly supported with those two springs. Any other ideas. I do notice it is hard to close the clam shell, can that cause it to jam and turn off.
          Thanks,
          Brent
          • copier tech
            • 8176
            Re: Canon PC-745
            Originally posted by bbenson40@yahoo.com
            Hello,
            Thanks,
            Brent
            The spring mounts that support the upper clam shell used to break through the base of the machine causing this exact issue.
            You have done well keeping this 20+ year old copier going !
            • Brian8506
              • 1665
              Re: Canon PC-745
              There was a modification for the spring breaking through the base but you needed a special tool to compress the spring. If the clam shell opens a little the machine will shut off. The paper tray sensor flag used to break and bind in there causing jams.
              • GIUBOSS
                • 1436
                Re: Canon PC-745
                True...I forgot about the auto shut off, but I corrected some by making changes to the spring mount....many years ago
                • campy
                  • May 2012
                  • 315
                  Re: Canon PC-745
                  It's the exposure lamp. It's a florescent bulb and is not getting to full brightness so the machine shuts down.
