scanning from IR advanced C5250 to windows 11 computer
  • acsolutions
    • Jun 2010
    • 519
    [Misc] scanning from IR advanced C5250 to windows 11 computer
    Hello, I'm unable to scan to a windows 11 computer, I did set it up on a windows 10 computer. turned on smb and file and print sharing with firewall turned off, still says re sending then a tx report. says tx incomplete and transaction ok. Thanks
  • wcanonw
    • Aug 2014
    • 404
    Re: scanning from IR advanced C5250 to windows 11 computer
    hello not understand windows 10 or 11
    • acsolutions
      • Jun 2010
      • 519
      What dont you understand. I can scan to windows 10 smb but not to windows 11 smb that's about the best I can describe it.
      • wcanonw
        • Aug 2014
        • 404
        hello you have to put a fixed ip address to the computer, and create a password to the computer
        • acsolutions
          • Jun 2010
          • 519
          My windows 10 computer in not fixed and it works just fine. Yes, it does have a user name and password, you can't set it up without it.
          • copier tech
            • 8144
            You may need to update the firmware to support SMB 2/3.
            Windows 11 turned off SMB v1.0 by default this will block scanning from your Canon unless updated. See attached file.
            Special Firmware 46.80 SMB2 Support version 1.3.pdf
            • acsolutions
              • Jun 2010
              • 519
              [ATTACH]59186[/ATTACH]
              Thanks, I was afraid of that! I have no way to get that firmware due to not being an authorized dealer. Is there a ftp utility I can use?
              • copier tech
                • 8144
                We can supply you this firmware, drop us an email via either link below.
                • wcanonw
                  • Aug 2014
                  • 404
                  Another option would be if the computers are all in an office, the Windows 10 computer where the scans arrive, share that folder over the network, and from the Windows 11 computer to be able to access that network shared folder.
                  • dekoster
                    • Aug 2012
                    • 84
                    you can download the special software in service mode under updater
                    • dekoster
                      • Aug 2012
                      • 84
                      • acsolutions
                        • Jun 2010
                        • 519
                        Thanks guys, for all the options. The machine is at my home and I'm having my
                        wife scan to email until i select the option. Thanks again and I'll post when I get the scanning going.
                        • Canuck
                          Tech Specialist
                          • 1713
                          Make sure all of the Windows security updates are installed also.
