IRA C3525 E00196-00f
  • Larhal
    • 625
    Hi All,
    Could use a little insite to any possible causes for this. Manual states:
    E196-000F-05 Communication error
    Detection Description The number of read/write job data to the DCON EEPROM exceeded 100.
    Remedy [Related parts]
    - DC Controller PCB
    [Remedy] Check/replace the related harness/cable, connector and parts.
    [Reference]
    Before replacing the DC Controller PCB, back up the service mode data and restore the backup
    data after the replacement so the data may be able to be protected.
    - Backup: COPIER (LEVEL2)> FUNCTION> SYSTEM> DSRAMBUP
    - Restoration: COPIER (LEVEL2)> FUNCTION> SYSTEM> DSRAMRES.
    Is it typically a DC PCB issue or are there hidden causes.
    Thanks in advance for any help.
    Larhal
    If all else fails read the Service Manual!
    If that fails, meet me at the pub and we will discuss it.
  • Larhal
    • 625
    Re: IRA C3525 E00196-00f
    Strangely, I arrive at the site, power up the unit and no codes. Checked history and there were several E00196-00f codes. Checked and re seated all the connections on the DC PWB and associated harness just to insure it wasn't a weak connection. Ran 50 colour copies and no issues.
    As I said, Strange.
    Larhal
