Printing quality c5235 c5255 with fiery.
  • jvga2010
    • May 2012
    • 32
    [CQ] Printing quality c5235 c5255 with fiery.
    Hello Again
    My problem now with another c5235 is when we try to print with UFR DRIVER. 3 photo files of 10 MB each one. It says processing for a long time and then it shows a message that was an error during the printing.
    What can it be the cause? Because this machines should support this file size.
    And also I have been told of the fiery quality. That would be better. But I have got a c5255 with b2 fiery and the problem is that when we print with the driver, it take longer than ufr ii, is it normal?
    Thank you in advance
    • 8133
    Re: Printing quality c5235 c5255 with fiery.
    Originally posted by jvga2010
    Hello Again
    Both devices should be able to print a 10MB file easily even without a Fiery.
    I would start by updating the system software on the copier first see if that improves.
    • wcanonw
      • Aug 2014
      • 404
      Hello, does the printer have server b2? If it has a B2 server, you must install the driver for imagepass b2, the most current one that you can get on the official Canon website.
      • wcanonw
        • Aug 2014
        • 404
        If you are wanting to print with UFR, you must disable the server in COPIER-OPTION-INTERFACE-0 service mode. Then enter the IP address, subnet mask, default gateway. When you download the driver from the official Canon UFR2 site that ends in LT
        • jvga2010
          • May 2012
          • 32
          So you mean I should reload the firmware ?
          • jvga2010
            • May 2012
            • 32
            Yes I have done that but, the problem I noticed is that using the b2 driver for the same file takes longer to print than another machine without the fiery server and using ufr I driver. My question is if that is normal to happen.
            • wcanonw
              • Aug 2014
              • 404
              Canon UFR II/ UFRII LT Printer Driver
              • wcanonw
                • Aug 2014
                • 404
                It is not normal for it to take a long time to print with the B2 server, try updating the server system. If the problem persists also in the ufrII driver option, update the firmware and check the ram memories.
                  • 8133
                  Well not exactly reload the firmware, you can simply update it.
                  • jvga2010
                    • May 2012
                    • 32
                    How do I update it?
                      • 8133
                      How do I update it?
                      Either via the service mode or we can supply it for you to update via USB pen drive.
                      Feel free to contact us via either web link below to discuss.
