gp405
  • jinjangu
    • Jul 2008
    • 39
    gp405
    i have accidently shorted one of the fusing exit sensor's wire to the machine body.
    now it show a massage " close front cover" when i swith it on[the cover is properly closed], then a error code 805 pop out.
    there must be a electrical board defective.I wonder which board is spoiled.
    someone can tell me???
    • 23008
    You have lost one of the DC voltages from the power supply, probably 5vdc or 24vdc. The 805 code is a fan error code, so I would suspect 24vdc.
    If you're lucky you might have a blown fuse on the power supply. Canon does not put many fuses on their power supplies, so you'll probably have to replace it. You can meter out the outputs from the power supply to determine which output is missing.
    There is a more remote possibility that you toasted the main controller. =^..^=
    • jinjangu
      • Jul 2008
      • 39
      thank you very much for your info
      • rosaro75
        • Mar 2009
        • 87
        this problem due to absance of dc 24v from composite power supply. if it ok check fuse in dc controller
        • mata
          • Mar 2009
          • 46
          hi,,, i have a problem with canon gp 405...error e677...and how i can add new software to printer hdd??? thanks email : matabg@gmail.com
          • mrfixit51
            Lead Service Technician
            • Oct 2008
            • 1975
            Your multiple questions have already been answered...
            You have placed the same request for information in multiple threads. This practice of placing a request at the end of a dead thread is not a good way to get the information you seek.
            Create a new thread! That way you will get a better level of response. And instead of posting in all these old threads, take the time to read the replies...
            I have already given you detailed advice on how to accomplish the task....
            http://www.copytechnet.com/forums/ca...non-gp405.html
            • mata
              • Mar 2009
              • 46
              Sorry for that. Junior tech was afraid to ask me first. He'll be killed and thrown to the pigs.
              Anyway. I have e677 on two machines. A customer send something for print and machine printed few sheets, than three blank sheets and than e677. I dig out old gp 405 of mine that worked fine a year ago, connect network cable, turn it on, print some jobs and then e677. Am I lucky or what? Is printer board dead or system software brokes?
              One more thing. Printer board can format HDD but can't boot or run system setup.
              Cheers
              • mrfixit51
                • Oct 2008
                • 1975
                I make the attempt at recovery in the manner I described first, but if this fails, I then go to plan B and see, as you did, if I have a donor I can tap for a replacement. Plan C is more expensive, had to go that route a couple times this past year, and call up Hytec, or Nationwide to see if they had any servers rebuilt. I have heard of people replacing the hard drives, probably an old working one out of a 2200 would work. The old copiers are pretty reliable, but there comes a time when we need to get our customers to move into the next decade, and buy some new technology...
                Good luck!
                • mehta
                  • Oct 2010
                  • 11
                  Re: gp405
                  Please check composite power supply.
