Canon c5235 Registration
  • jvga2010
    • May 2012
    • 32
    [CQ] Canon c5235 Registration
    Hello Again
    Today I received a machine that has a bad registration, the color are not synchronized.
    I have tried changing
    - main controller 1
    - laser units (both)
    - main controller 2
    - ITB
    SL1 is tested and patch has been cleaned (not changed)
    What else can it be?
    Please your help will be appreciated.
    Thank you In advance
  • Asaadahmed003
    • Jun 2019
    • 24
    Re: Canon c5235 Registration
    Try to re-entry the values in the birth certificate found in the inside of the front door and do gradation adjustment
    • jvga2010
      • May 2012
      • 32
      • doktor
        • 214
        DC -CON clear ?
        • jvga2010
          • May 2012
          • 32
          Originally posted by doktor
          DC -CON clear ?
          • Venom
            Technical/IT Support
            • Nov 2009
            • 765
            verify the drum units are seated properly, front side could not be in far enough and that could cause that
            IBM, Mita, Konica Minolta, Ricoh, Kyocera, HyPAS, Canon, Oce, Samsung, HP, TEO IP PBX/Unified Communications, Comptia Network+ Comptia PDI+ Certifications
            • Asaadahmed003
              • Jun 2019
              • 24
              [QUOTE=jvga2010;2535442]
              I must say that grid test comes with different separations of color. To make that more clear, in the upper part of the page the colors have a 5 mm separation but in the end of the page the colors match. What could it be?
              That's weird if it match in one side it should match on the other... Can you upload a scan from the PG10 test page? And are you printing SEF or LEF?
              • giogi
                Engineer senior
                • Jan 2016
                • 181
                Try launching these service modes
                Lerv2 COPIER > FUNCTION > LASER > LD-ADJ-Y M C K
                Lev1 COPIER > FUNCTION > MISC-P > AT-IMG-X
                "Knowledge is a source, but unfortunately ignorance is a sea."
                • wcanonw
                  • Aug 2014
                  • 404
                  Hello, if you can send a photo of test 6 and test 10.
                  check the drums if it is original or compatible, if the drum is original, check the transfer unit, perform its maintenance, after performing the maintenance on the itb, perform init itb and atx-img in service mode
                  • wcanonw
                    • Aug 2014
                    • 404
                    If making the adjustments in the service mode and the failure continues, enter the service mode again and in adjust-regist, set everything to zero and click ok, turn the machine off and on. then to try....
                    • copier tech
                      • 8172
                      Try running REG CLR in service mode level 2.
                      Copier > Function > Clear > REG-CLR.
                      Also check the patch sensor cover is moving freely, or simply remove it.
                      • Radiscar
                        • Jun 2019
                        • 74
                        to clarify: the gaps/issue is at the bottom of the page, so from the front of the copier?
                        if its recently received...my guess would be drums, itb, or a bent frame but you have already replaced the itb assy.
                        do the color lines on the grid crisscross in any way or just shows up separate?
                        • MunsterTech
                          • Sep 2014
                          • 381
                          Is the patch sensor shutter actually moving? The solenoid actuates but the shutter can stick
                          due to the plastic nipple breaking off.
                          • jvga2010
                            • May 2012
                            • 32
                            Hello again with everyone. It turned out the problem was the HDD. We changed it again with a working one and it worked fine. Physically everything recommended was ok
                            • copier tech
                              • 8172
                              Interesting, never see an HDD cause a print registration issues on a Canon.
