Canon IRC 5535 administrator log in password unknow, how to reset
  • tech28
    • Jun 2013
    • 434
    Person with information left business and didnt tell anyone password. Need to know how to reset. Have gone into service mode and cleared passwords and on/off to no avail.
    Thank You!
  • Saturn
    • Nov 2023
    • 167
    Re: Canon IRC 5535 administrator log in password unknow, how to reset
    I only know PWD Clear in service mode.
    I don't care about who your father is, as long as I'm fishing here, you won't walk on water.
    • Venom
      Technical/IT Support
      • Nov 2009
      • 765
      Seems to me if firmware is loaded on usb and you enter download mode, there is a password clear listed...as well although i have never needed it.
      IBM, Mita, Konica Minolta, Ricoh, Kyocera, HyPAS, Canon, Oce, Samsung, HP, TEO IP PBX/Unified Communications, Comptia Network+ Comptia PDI+ Certifications
      • giogi
        Engineer senior
        • Jan 2016
        • 182
        security policy
        Lv2 Copier > Function > Clear > PLPW-CLR
        "Knowledge is a source, but unfortunately ignorance is a sea."
        • tech28
          • Jun 2013
          • 434
          Still nothing working, will not allow entry. Isn't there a reset in the service mode to reset board or something to that effect? Thnk there was something in the 3380's.
          Anybody can think of something else, please let me know.
          • giogi
            Engineer senior
            • Jan 2016
            • 182
            What you say is very strange.
            the instructions I gave you work and delete any psw.
            can you kindly put a picture of the situation you see on the LUI?
            • Radiscar
              • Jun 2019
              • 74
              Power off/reboot the copier if you haven't already; sometimes if too many passwords attempts occur the copier wants a hard reset. I think its something to prevent hackers from remoting in and trying to crack the device.
              If all that still doesn't work and you really need to get in...make sure you grab all the network settings you have and confirm the scan settings and just wipe the copier.
                • 8104
                Originally posted by giogi
                security policy
                The answer was posted days ago. This will reset the admin id & password to default.
                The default user name for the administrator is "Administrator" and the default password is "7654321"
                • ADV COPIER
                  Pemain
                  • Nov 2022
                  • 243
                  Originally posted by Megha Colsins
                  I also have same confusion, Please anyone solved this problem of solution.
                  reinstall system software. done
                  Let's Drink our Coffee
                  WhatsApp +62895325228383
                    • 8104
                    Reinstalling the system software does not reset the administrator / login password.
                    • RicheyRich80
                      • Oct 2023
                      • 8
                      Thank You!
                      go into service mode function, clear, PWD-CLR, power reset
