Canon Scan to SMB error
  • Printer77
    • Sep 2019
    • 58
    Every month all canon copiers won't send scanned using SMB. I always change user password to same or remove latest windows security update and then work's normally. But that's repeat every month. Is there solution for permanent work?
  • ADV COPIER
    Pemain
    • Nov 2022
    • 248
    Re: Canon Scan to SMB error
    check SMB protocol
    Let's Drink our Coffee
    WhatsApp +62895325228383
    • apollo
      • Mar 2008
      • 182
      Are you using ip address or pc name, ip address changes all time lease expires and new ip address gets assigned.
      Model no copier ?
      • Printer77
        • Sep 2019
        • 58
        Model no copier ?
        I use PC name. But it happens on models Canon IR1133if, IR 4025i, IR2520i, IRC3320 and similar models to that.
        • Saturn
          • Nov 2023
          • 171
          What machine are we talking about?
          I don't care about who your father is, as long as I'm fishing here, you won't walk on water.
          • Saturn
            • Nov 2023
            • 171
            Is the latest firmware installed?
            • Brian8506
              • 1664
              You need the special firmware for smb 2&3
              • Printer77
                • Sep 2019
                • 58
                All of them. They some use SMB 1 but some use SMB 2&3. All printers have latest firmware installed.
                • zoraldinho
                  teacher-guide-expert-guru
                  • Mar 2008
                  • 5005
                  On Windows, create a new user without a domain, which is not linked to office 365, and it will always work.
                  • Printer77
                    • Sep 2019
                    • 58
                    I use local account named "Scan" but it's still happening.
                    • Canuck
                      Tech Specialist
                      • 1713
                      Do you have special SMB 2/3 firmware installed on machines? And "latest firmware" has nothing to do with it. What Windows OS version are they running on computers?
                      • Londo
                        • May 2021
                        • 15
                        If you are using local user make sure that 'password never expired' is ticked
