IR2800 hdd
  • copyman
    Owner / Technician
    • Sep 2005
    • 4692
    IR2800 hdd
    Hi
    Anyone have a Canon IR2800 hard drive new or good used with the system software on it to sell? Not sure if it matters with HDD but this customer only copies with old machine.
    Think it's same HDD as the IR2200, 3300?
    Please PM if you have one and will work out payment details.
  • ADV COPIER
    Pemain
    • Nov 2022
    • 255
    Re: IR2800 hdd
    Originally posted by copyman
    Hi
    yes, same ide 2.5 inch
    Let's Drink our Coffee
    WhatsApp +62895325228383
    • copier tech
      • 8144
      Re: IR2800 hdd
      Hi
      You can find these on eBay, remove the old HDD & buy an IDENTICAL one. You'll then need to install the system software via laptop & parallel cable.
      • copyman
        Owner / Technician
        • Sep 2005
        • 4692
        Re: IR2800 hdd
        Yes I saw them on ebay and have the system software from years ago. But problem is I don't have a laptop with parallel port to take to customers office. This is why I asked if someone had a good HDD with sys soft already on it.
        • copier tech
          • 8144
          Re: IR2800 hdd
          Yes that is the issue. However you could also pick up a cheap Win XP laptop with a parallel port on eBay too.
          • copyman
            Owner / Technician
            • Sep 2005
            • 4692
            Re: IR2800 hdd
            Will something like a USB to parallel cable work using Win 10 laptop?
            Thanks again
            • ADV COPIER
              Pemain
              • Nov 2022
              • 255
              Re: IR2800 hdd
              Thanks again
              You can't run it on Windows 10, as far as I know, the maximum is on Windows 7
