Canon Copier Question
  • krashthrills
    • Aug 2025
    My sister passed away leaving me an copier called the Canon C300. Its a big old machine. I am trying to install it in my friends business and when I turn it on it says "Insert your Control Card".
    Bottom line is I do not have a control card. I have already removed the actual control card reader because that is what some dude from a Canon Authorized Dealer told me to do but the message still comes up when i power up the machine. Is there anyway to make this go away so we can just make copies. PLEASE PLEASE PLEASE help! Thanks.
    Call me at 909 263 0763 and I will be eternally grateful
  • KenB
    Geek Extraordinaire
    • Dec 2007
    • 3944
    When you removed the control card reader, did you reinstall the jumper from where you disconnected it?
    I know nothing about the C300 (as you stated, it's quite old), but that's how it worked with other models.
    I remember that typically we would attach the jumper very near where the connector was with a wire tie so that it could be reattached if and when it was required.
    There's nothing magic about the jumper; it simply shorts two pins together. (In fact, we would sometimes install a key switch instead of a control card if cost was a factor.) The other two wires, as I recall, were 24 volts, so it goes without saying that shorting the wrong two together could, OK, would, prove disastrous.
    I sincerely doubt that it would be possible at this point in time to find a schematic for that model, but I'll let you know if I find one.
    Good luck!
    • krashthrills
      Thanks buddy
      yeah that would be cool if you found that but i am not expecting it my friend. what i did was unscrew the control card reader itself which was attached withlike a plug thing with about 6 wires to the opposite plug thing (for lack of a better word)and no i didn't reattachit to anything it didn't appear that anything else attached to it. but i will have another look.
      thanks alot dude
      • Oze
        Ricoh Fanboy
        • Jul 2008
        • 1663
        thanks alot dude
        Pull some covers off and have a look as sometimes techs hide the plug somewhere on the machine so that customers couldn't run off free copies.
        • peterepeat
          • 84
          Under/inside the control panel will be a 4 pin connector that the reader was connected to. Take a paper clip or wire and jump the 1st & 3rd pins. Wrap it up in elec tape & you're done.
          • Brian8506
            • 1665
            The jumper is on the underside of the control panel. I have one if you get into a bind. You may even find it under there.
