good day to anyone! I have a irc-6800 with error of e00800-000. Can anyone help me what to do to fix it? I thank to those who have a helpful heart and may god bless you. Hope you can spare time to answer my inquiry. thanks!
Check to make sure that a user hasn't closed the front door without locking the fixing feeder drawer handle.
You can still close the front door with the handle in the down position and it'll give you the E800 interlock error code.
How do I know?
I got called to an iRC5880 yesterday for the same code...they'd pushed the drawer back in and closed the door without locking the drawer in place by turning the handle to the upwards position.
Oze is right on it. I would only add to tighten the screws for the door hinge because that is what normally allows enough play in the door so it gets over the green handle.
Many thanks to everyone who reply. I will try your suggestions as soon as i have my chance on that machine. Up to now it is still not working. i will post the result.
Thanks a lot the help! Thank you!
Could also be the cam that works with the green handle in the rear of the bed. It can be deformed/worn. Make sure that the handle stays up and does not drop too easily.
The glass maybe half full, but less is more...
Printer + Fax + Copier = Jack Of Many Trades,
but Master Of None
Color Copier = Not A Color Printer
InkJet MFP = Not A Fax Machine
B/W Copier = Not A Press
Finisher = Deal Closer (salesman, not accessory)
Copier Tech = Admin's Stress Ball (Scapegoat)
The 6800/5800 is a P.O.S. This machine should go in the s**t can along with IRC3100 & CLC. Dont let them sell you a IRC5058. Same pig different lipstick...
The 6800/5800 is a P.O.S. This machine should go in the s**t can along with IRC3100 & CLC. Don'T let them sell you a IRC5058. Same pig different lipstick...
if there problem in right door switch also give this problem. if the sensor interrupted condition the right door switch released then it shows E-800. so change sensor also
go to service mode and reset life of fuser go to counter and misc
