CANON IR C3200
  • Charger
    • Jan 2008
    • 12
    CANON IR C3200
    I have a irc 3200 that we picked up for service and wont have a manual on for a couple of days. Can anyone tell me or scan to me the procedure/service mode calibrations for color alignment. every thing looks ok with each individual colors just they out of align with each other a millimeter or 2 for each color. any help would greeatly be appreciated.
  • 11x17
    • Apr 2007
    • 153
    Try doing a quick auto grad adjust. If that doesnt snap it back then youll need service. Most likely the itb is slipping or the lasers are out of adj. Also a DC controller clear has fixed this for me.
    I would put money on having to disassemble the itb and clean the drive rollers and inside of the belt.
    Good luck
    • mrfixit51
      Lead Service Technician
      • Oct 2008
      • 1975
      To add to what 11x17 had to offer, there are the 3 gears that drive the ITB asm, and quite often there is some play in those. It takes very little to get the affect into the copier, and then it seems to remember this offset for the rest of whatever. The best test print to view this effect I have found is #31. All the lines should line up neatly in a row, and when the colors are misregistered, it really shows up on this pattern.
      FU3-0266-040 Gear on ITB
      FU3-0546-000 Single gear in cluster
      FG6-9662-000 Swing gear cluster asm
      When you clean out the ITB asm, besure to wipe down the inside of the belt, as well as washing the 3 rollers with alcohol.
      • Desert Rat
        • May 2008
        • 1089
        Charger,
        The new style gears on the ITB are black. You may also want to check
        the front to back tightness of the drive rollers. Shims may be added to
        reduce the "free play".
        It is my understanding, and I may be incorrect, that if the miss registration
        is off left to right as the page exits, it is probably a dirty ITB assy, a
        sloppy gear or roller free play.
        If it is off front to back the laser cams may be in the wrong position.
        DR
        • SCREWTAPE
          • Jul 2025
          Most likey its the lasers. If you clear DC, which I recommend not if you are not a tech!. But, if you do and the problem disappears, you can eliminate the ITB being the problem. If the problem comes back, most likey it will be the lasers. Make sure the machine firmware is up to date with the latest and greatest software.
          • mtk525
            • Sep 2008
            • 8
            Depending on the condition of your ITB belt, a simple cleaning behind the belt of the drive rollers and a wiping of the inside of the belt might work. If you keep your drums in longer than thier life they will leak toner that will end up behind the belt causing it to slip. If that does not work, print the P-Print and then do a DC-Con clear and re-enter all changed values both level 1 and 2.
            • jprecht
              • Dec 2008
              • 104
              offset colors
              make sure everything is clean on tba, clean the timing sensor array, reboot through service ,function ,clear,mcon. if prob persists than follow the excellent advice of 11x17 and mr fix it!!! good luck bear
              IT IS BETTER TO REMAIN QUIET AND BE THOUGHT A FOOL
              THAN TO SPEAK AND REMOVE ALL DOUBT
              • Desert Rat
                • May 2008
                • 1089
                Charger,
                I have a tech letter on this problem. But have no idea on how to post it
                on the board. PM me with your email and I will send it to you. It has
                helped me address this problem in the past.
                See Ya
                DR
