IR 3300
  • Vesigoth
    • Mar 2008
    • 133
    IR 3300
    I've got this Image runner 3300 displaying E000051-0000. If you know what this code is and how to clear it please advice. Thank you.
  • nivssluck
    • May 2008
    • 228
    E051
    0000 At start-up, home position is not detected when the horizontal registration
    assembly is moved 100 mm in the direction of home position.
    Main cause The horizontal home position sensor is faulty. The horizontal registration
    motor is faulty. The DC controller PCB is faulty.
    Action
    1. Connector
    Are the connectors of the horizontal registration home position sensor and
    the horizontal registration motor connected?
    a. DC controller PCB (J304) <-> relay connector <-> horizontal registration
    b. DC controller PCB (J304) <-> relay connector <-> horizontal registration
    motor
    NO: Connect the connectors.
    2. Sensor lever (damage and interference), Sensor
    Is abnormal noise heard from the horizontal registration assembly in keeping
    with the motor rotation?
    YES: a. The horizontal registration assembly is out of place because of
    damage to the sensor lever. Replace the sensor lever.
    b. The horizontal registration assembly malfunctions because of the
    presence of foreign matter. Remove the foreign matter.
    c. The sensor is faulty and cannot detect home position. Replace the
    sensor.
    3. Horizontal registration motor, DC controller PCB
    Is the horizontal registration motor control signal generated by the DC controller
    PCB?
    J304-1/2: 24 V, J304-3/4/5/6: motor excitation signal
    YES: The horizontal registration motor is faulty. Replace the motor.
    NO: Replace the DC controller PCB.
    • toantam
      • 63
      E 051
      Dear Sir
      E 051 is the horizonal motor problem, you can take out the pick up ass'y. On the motor have a small gear, sometime this gear broken.
      Good luck to you.
      • roho
        • Mar 2009
        • 844
        E 051
        I've had acouple of these in the past. I've never had to replace anything, the horizontal reg motor became stuck in the wrong position. I was able to manually move it back and rebooted copier. Not sure why the motor was in the wrong position-cust related?
        You have to remove the pick up assembly, hor reg motor is on the top!
