ADF S1 JAMMING.
  • SCREWTAPE
    • May 2025
    ADF S1 JAMMING.
    I had this ADF from a iR5055 that was jamming on a frequent basis.
    The jam codes were 0004-0007-00012. The point at were it was jamming was by the scanning area in the feeder. It would fan up, or at times you could see a indent at the lead edge of the paper upon delivery. I checked everything from sensors to cutting wire ties, Replaced one of the stepping motors. I pulled out the lower delivery guide because it was the last thing that paper passes thru. I inspected the guide and notice that the guide was slightly warp, first problem. Second problem, there is a flapper that attaches to the guide with a spring hook, this also was affected by the guide. It'd seemed as if the holes on the guide were a bit to small for the flappers shaft. When I replaced these parts today and attached the new flapper to the guide, the flapper moved so smoothly unlike the other one, it would hesitate when opening I believe this was the reason along with the warpness of the lower guide that caused the paper to crash into the flapper. I attached some photos. Maybe this would help someone one day.
    Screwtape.
  • Kopyrtek
    Copier Psychologist
    • Jan 2007
    • 407
    Screwtape, how you been?Nice pics by the way.Have to save them and pass around to the techs.Thanks for the heads up on the ADF.
    • SCREWTAPE
      • May 2025
      Everything is good my friend. Pass em around, as i said it may save someone from pulling there hair out. LOL
      • Kopyrtek
        Copier Psychologist
        • Jan 2007
        • 407
        Know what you mean!!Every bit of help is appreciated.
