Canon IR6000 E0003, E0001
  • Desert Rat
    • May 2008
    • 1089
    About three weeks ago it gave an E0003-0000 code. I cleared it
    and ran appox 200 pages. No troubles. The customer mentioned that the
    front door was open for a while. I noticed that the A/C was blowing on
    the area of the fuser when openned. I adjusted the vent to blow away
    from the machine and ran more copies. No toruble.
    Last thursday the machine displalyed an E0001-0000. I went over and
    changed the two thermistors and the thermostat. After that the machine
    would not warm up to ready. The temp got to about 170c. I heard a
    click in the back and it began to cool. I saw both lamps come on bright.
    I checked the connectors for paper, none found. I scrapped, very carefully, the contacts with my knife. I also cleaned the high voltage
    spade connectors to the lamps. Ohmed the lamp (4.5ohms) and checked
    the wiring. I did not see anything odd in the connectors on the back of the fuser. I happen to check the alarm log the only code I saw was
    020002 0000. This machine has logged serveral of these over the last
    2-3 months.
    Has anyone else seen or heard of something like this happening?
    I have not defined the alarm code yet.
    Any help appreciated
    DR
  • SCREWTAPE
    • Aug 2025
    and ran approx 200 pages. No troubles. The customer mentioned that the
    the area of the user when opened. I adjusted the vent to blow away
    from the machine and ran more copies. No trouble.
    Last Thursday the machine displayed an E0001-0000. I went over and
    spade connectors to the lamps. Ahmed the lamp (4.5ohms) and checked
    020002 0000. This machine has logged several of these over the last
    2-3 months.
    DR
    Try adding some shims on the fixing ass'y connectors, the shims are those gold plated small washers. This will help those male and female connectors make contact a little better, also check wires for any pinches, cut wires ties on the wires that trace to the dc from those terminal connectors. Check the leads on those lamps as well. Worst case scenario you might have to replaced the power supply or Dc controller. Good luck.
    • Desert Rat
      • May 2008
      • 1089
      Thank you screwtape,
      From what I have seen on the Canons almost all the tie wraps look
      to tight. Someone else mentioned shims too. After re-reading my post
      I see I forgot to mention one last symptom. And I believe it points
      at the connector. The red error lite on the panel would lite. I open the
      front door and the message to reset unit 1 was displayed. Sometimes
      it would go off by resetting unit1 other times I would cycle the pwr sw.
      DR
      • mujibur
        • 53
        E002
        E003
        E004
        Main Cause The SSR has a short circuit. The DC controller PCB is faulty.
        Mode of
        Detection
        0000 The SSR used to drive the fixing heater is found to have a short circuit
        (hard circuit detection).
        Caution The error must be reset in se
        • 20YRSEXP
          • Oct 2008
          • 281
          I have seen where the rails the drawer rides on can cause issues like this. If the rails are either loose or fatigued they will sag and cause poor contact.
          Is the glass half full or half empty? I say neither. The glass is obviously full, full of potential. The potential to hold more water or the potential to quench a thirst. Life is all about how you see it.
          • SCREWTAPE
            • Aug 2025
            I can see how the two problems can relate to a E003. Have you check the micro switch(MSW3)-J271 on the DC. The switch is by the fixing feeder frame ass'y handle, the green one. If you look in parts catalog, its figure 320, item 36.
            • Desert Rat
              • May 2008
              • 1089
              Screwtape, 20yrsexp and mujibur,
              Thank you for your replys. Yesterday I happen to check that MSW3
              switch. When closed, after the click, if I moved the actuator within
              the space after the click, I could get several different readings.
              From 8 ohms to 112. My meter isn't very fast on the display. But enough
              that I could see a problem. It should be open or closed.
              Droopy rails. Sometimes I forget to check the screws and make sure they
              are tight. The drawer slides in and out easily and I did shim the fuser
              connector toward the female connector in the back.
              How much can one shim that connector? I used washers about 1mm thick, maybe slightly more.
              Thanks for your time
              DR
              • Desert Rat
                • May 2008
                • 1089
                I forgot to ask about the frequency of replacement for that switch?
                And what about that fuser connector relay board? I noticed that
                it is buried in under the exit path. How much trouble has that caused
                in the past?
                DR
                • Desert Rat
                  • May 2008
                  • 1089
                  I did not get the switch. But I made a shorting plug so the machine
                  would think the switch is in the closed position, and think the unit 1 is
                  closed.
                  Didn't work. Same symptoms. Each time I can see the I/O display for
                  that switch MSW3 change states. It never starts to run to complete
                  the warm up cycle.
                  A friend mentioned the duplex tray can cause odd problems. In this model
                  the duplex tray is part of unit 1. I will have to check that tomorrow.
                  Something to think about
                  DR
                  • Canuck
                    Tech Specialist
                    • 1713
                    Is upper fuser roll in good shape? I've seen them wear in the area where end thermistor "rides" on. Thermistor touches bare aluminum. When you changed the thermistor(main) did you change the assembly that holds it...I've seen it when the thermistor translates back and forth on the upper fuser roll, it will lift off the roller. Usually just gotta clean fuser oil(web) from spring and assembly. It sounds more like you have a drawer problem. Use a spring hook and re-bend the pins/tabs in the connector. Hope you put in correct thermistors..Main...FH7-7529...Sub...FG5-8812. There is also a fixing/feeder connector pcb...FG6-4979....under the fuser.
                    • 20YRSEXP
                      • Oct 2008
                      • 281
                      Speaking of micro switches. The micro switch that the multifeed door actuates has been known to cause strange problems. For that matter anything running on 24v that has a problem can interfere with signals. If you are hearing a click in the back just before it shuts down I would check... I think it is called relay3, it can have problems and that is where the charge to the lamps runs through.
                      • 20YRSEXP
                        • Oct 2008
                        • 281
                        After doing some reading I think it is the main relay you want, but don't forget the AC Driver. The fuser voltages run from there.
                        • Desert Rat
                          • May 2008
                          • 1089
                          20YERSEXP & Canuck,
                          Thanks for the replies.
                          Canuck, the upper roller is not new, but is not worn to the point that you describe, the machine nevers starts rotation from a cold start. That main
                          thermistor assy is free of dirt and oil and both thermistors are on the roller.
                          I checked the p/n's and they are the ones that you listed.
                          I will go their today and check to see if the FFUS* signal changes at the
                          DC Controller connector.
                          20Yrsexp, I noticed that relay connector board in the diagrams. I could
                          not see it from above or below. It must be buried in there somewhere.
                          I will have a look for that relay 3 and the fuser connector board.
                          If that relay 3 is the cause, what would cause the FFUS* signal to change
                          states if the connector on the switch is shorted?
                          As far as the 24vdc line, that would be some kind of electrical noise on the
                          line. What is the most common cause? On the analog kodaks some of the
                          24v motors have been known to mask inputs to the cpu board. Same
                          principle I would think?
                          Any thoughts on the duplex tray confusing the cpu?
                          Thanks for time and help
                          DR
                          • 20YRSEXP
                            • Oct 2008
                            • 281
                            MSW3 goes thru the fixing/feeder relay PCB. If the switch is changing to open and it's not the switch it could be that PCB. I've known it to have trouble, not often but it's not out of the question. If FFUS is not going to open I would check the relay 1 signal and see if it goes to off when you hear the click. If it does not go to off it could be a bad main relay. If these both check out I would go back to changing the DC con. But remember the AC driver can cause all those codes also. If you have all the boards in stock head out with B.O.B (box of boards) and just replace what you need.
                            • Desert Rat
                              • May 2008
                              • 1089
                              It is up and running,
                              The last three things I did were, remove the fuser tray and tighten the rail
                              screws. The left side had some wiggle. All of the screws needed to be
                              snugged down. As long as the tray was out, I started to loosen the wire
                              harness on my way to the relay board. I also reseated connectors on the
                              way in. I did remove a few loose staples on the way.
                              I put the old bad switch back in and it warmed up and ran a couple
                              hundred copies. No trouble.
                              Thank you everyone for your time, expertise and effort in helping to
                              solve this problem for me. I count this board as one of my best tech
                              resourses. I do have some other questions but I have to get out the
                              door this AM.
                              Thanks again
                              DR
