Cleaning The ir8070 Drum
  • abkonnet
    • Mar 2008
    • 166
    Hi the Drum of IR 8070 Have toner dried in to spots. This Produce white spots in the copies made. Can i use IP or Tinner to clean the Drum? which one can be used pls suggest me.
  • faisal jilani
    saad jilani
    • Sep 2008
    • 40
    use zanic powdar with watar only
    • alex@wocltd.com
      • 430
      try these -
      10 x Magic Eraser - Cleaning Dirt Erasers Sponges on eBay, also, Cleaning Products Supplies, Cleaning, Laundry Vacuuming, Home Garden (end time 09-Jul-09 21:14:54 BST)
      • Canuck
        Tech Specialist
        • 1713
        I use Vim...thin it out a bit...no chunks...works great(same with Soft Scrub).Pop the cleaner blade assembly out, do it right in drawer
        • SCREWTAPE
          • Aug 2025
          Back in the days when I worked on IR600's I used to used alcohol and a lint free towel and buffed the drum when I notice speckles on images and PG5's.
          I also buffed out those specks out right from where the developer is at. Pull out the developer and clean them off the drum. Save me time and worked like a charm.
          • Brian8506
            • 1665
            I use Brasso on tha ASI drums and it works great.
            • reza
              yes use brasso and clean with any alcohol base cleaner and coat the drum with drum powder increase drum blade pressure
