Hi the Drum of IR 8070 Have toner dried in to spots. This Produce white spots in the copies made. Can i use IP or Tinner to clean the Drum? which one can be used pls suggest me.
Cleaning The ir8070 Drum
Back in the days when I worked on IR600's I used to used alcohol and a lint free towel and buffed the drum when I notice speckles on images and PG5's.
I also buffed out those specks out right from where the developer is at. Pull out the developer and clean them off the drum. Save me time and worked like a charm.Comment
reza
yes use brasso and clean with any alcohol base cleaner and coat the drum with drum powder increase drum blade pressureComment
