Canon IR 210 lift
  • nmfaxman
    • 1702
    Canon IR 210 lift
    Been too long since I worked on this box.
    Lower lift plate locked up and I can't remember how to make it drop.
    I know it is simple but I am having another Mucking Funday.
    Help.
    • 22947
    There's a white button on the surface of the PF unit that you can access through the front of the cassette port that will drop the lift plate. Usually there's more to it though. Stripped ratchets, broken springs, etc. =^..^=
    • mrfixit51
      Lead Service Technician
      • Oct 2008
      • 1975
      this may help...
      Help.
      You can remove the screws from the front side of the paper feed asm, that would be the left side of the asm as you are facing the right hand side of the copier. Pull the asm towards you at the front a bit and the lift gears should disengage from each other.
      If that fails, just pull the entire feed asm out...
      good luck
      • andy21557
        Help Desk Technician
        • Jul 2009
        • 62
        ir210 lifter arm
        Sometimes you can take grab the lifter plate ARM push it in towards the rear of the ppr feed unit the arm will release
