Ir 4570 tray "c" missing????
  • SESHU
    • 163
    HI..
    I AM USING FAX SEND/RECEIVE DOCUMENTS THROUGH OUT TRAY "C"..
    O.K
    BUT RECENTLY SOME INCOMMING FAX DOCUMENT COMES INTO TRAY "C " AUTOMATICALLY ...BUT JAM INTO THE PAPER IN TRAY "C"
    I CAN REMOVE THE PAPER AS WELL AS AND POWER OFF THE SYSTEM AND ON.
    THEN AFTER TRAY "C" OPTION MISSING...
    ALL COPIES FAX AND PRINTER DOCUMENTS ARE COMES OUT INTO TRAY "B"..
    I CAN TRY TO SET TO A TRAY "C".. TRY TO LIKE THIS WAY TO GO.....ADDITIONAL FUNCTIONS> COMMOM SETTINGS> TRAY DESIGNATION> ?????
    THERE WILL BE DISPLAY THE TRAY "A" AND TRAY "B"...
    BUT THERE IS NO DISPLAY THE TRAY "C" OPTION???
    HOW CAN I GET IT BACK TRAY "C" OPTION ??????
    PLEASE GIVE ME SOLUTION ....
    WAITING FOR UR REPLY FRNDS...
  • roho
    • Mar 2009
    • 844
    Do you have a warning at the bottom of the screen that says "limited functions on"?
    • SESHU
      • 163
      There is no warning message display ..
      NO.
      no warning message display about tray "c" OR LIMITED FUNCTIONS MODE ????
      • SCREWTAPE
        • Jul 2025
        There are some things you must do in service mode to correct that Missing option.
        • andy21557
          Help Desk Technician
          • Jul 2009
          • 62
          tray help
          There are settings in Service Mode in order for Tray C to show and be selected in Additional Functions>Common Settings>Tray Designation. The settings can be found in, COPIER>OPTION>ACC>OUT-TRAY>set to1, and COPIER>OPTION>ACC>>IN-TRAY>set to 1. Both of these Service Mode settings must be set to 1 in order for the machine to display Tray C.
          • mrfixit51
            Lead Service Technician
            • Oct 2008
            • 1975
            Andy has indeed given you the answer as to how to re-establish external tray C back to existance. What baffles me is how did turning off the copier and back on blow out the setting in Options??
            "Strange things are happening at the Circle-K"
            • SCREWTAPE
              • Jul 2025
              I feel the same as mr fixit, how did the machine reverted back?
              This is why I refrain from answering, but thanks andy21557.
              • SESHU
                • 163
                Thank you for replying andy..
                i am checking copier rear side and tray "c" side what they myfixit said.
                all components are very good.
                next i can do andy what he said...
                i can set it waht you say "COPIER>OPTION>ACC>OUT-TRAY>set to1, and COPIER>OPTION>ACC>>IN-TRAY>set to 1. Both of these Service Mode settings must be set to 1 in order for the machine to display Tray C.
                after then display the tray "c". after missing the tray "B". only two tray will be displayed tray "c" and tray "A".
                display the Tray "C" avd working fine tray "C"..
                but tray "B" missing.??????
                i can set it go the back default settings like OUT-TRAY>set to 0 and IN-TRAY>set to 0. as well as display tray "A" and tray "B". no display the tray "c".
                now i can set it it OUT-TRAY>set to 1 and IN-TRAY>set to 0. now see again. display tray "A". and Tray "C". Tray "B" again missing.
                now power switch off and on the copier . now displayed the three trays and working fine as.
                thank you very much andy.
                • Walestech
                  • Aug 2009
                  • 16
                  You may have a dead PCB in tray A or B.
                  • mrfixit51
                    • Oct 2008
                    • 1975
                    I just had a thought...
                    I never asked this question,, does this copier have an internal finisher or just the plastic trays....?
                    • SESHU
                      • 163
                      my copier have internal finsher. with small two trays A and B. staple also is there.
                      • SCREWTAPE
                        • Jul 2025
                        So after you set the value in service you must restart the copier for the change to take effect.
                        • SESHU
                          • 163
                          yes .. working.
                          • mrfixit51
                            • Oct 2008
                            • 1975
                            Now it's more clear...
                            I could not figure out how turning off internal tray was the fix,,, till you mentioned that there was an internal finisher. With that finisher installed, there is no change to the options settings, only the external tray. The finisher signals the copier that it is present, and the number of trays in the finisher is also handled by the finisher.
                            Glad you have it resolved!
