Dear Experts,
I have a CLC 1110 copier machine which make till now about 95000 copy and still look as new.
The problem is I have an error codes E071-0001 and E071-F000, and sometimes shows jammed paper on the TD (but no paper is jammed). I called a certificated service men they try a lot of variants to eliminate the errors, they replace the TD, replace the motor of the TD lifters and replace the motor of TD polisher, but without a result, they replace the DC controller even replace the electronic card of the TD and polisher lifter, also they replace the all base where the TD and fixing unit are lay, they clean and test all the sensors but without a result, they even take parts of my machine and try it on their machines and my parts work perfectly.
The problem also is the motor of the polish lifter does not lift the polisher at all on my machine even if it is ok and worked on other machines, and at this point my machine report error and even if the process of polishing pass which is in my case is rare, first copy stuck in the TD and again the error code appear again
Four service firm try to fix it but without a result.
Please you are my last chance and please consider that any information will help me
Please if any information or details needed, feel free to message me.
Thank you a lot
Thank you a lot
