Canon service support tool
  • pirijaa
    • Dec 2010
    • 14
    #271
    HDD IR C3200N
    Originally posted by teckat
    That HDD will have to be formated and wiped clean/of all it's HP information
    U then need the SST / AND to load 3200 firmware in SST program.
    then u put in the HDD in 3200/ then u need to use the 3200 firmware format file to format again.
    then u will be able to load the 3200 firmware on it.
    if all goes well-u may get lucky and have a copier
    Hy teckat
    In list of supported HDD is model SEAGATE ST340014A , and I have SEAGATE ST340017A , what can I do ? Please help me
    • teckat
      • 16083
      #272
      Give it a try, u still need the SST & FIRMWARE & A CROSSOVER CABLE
      Crossover cable is used between 3200 & your laptop for SST Communication to get Firmware on HDD
      see link>>
      http://www.homenethelp.com/web/explain/about-ethernet-crossover.asp
      Remember> It must be set for Master
      remember this HHD must be wiped clean before install/ & then Formated with the HD Format file in 3200 SST firmware
      • Petrus Janu
        #273
        I need SST to fix my copier. Can you help me please ..??
        Janouismadi@yahoo.co.id
        • philip1davies
          • Feb 2011
          • 23
          #274
          I Have SST and firmware for all canon
          Does anyone have Xerox manuals for swaps ?
          • teckat
            • 16083
            #275
            you say all Canon/ bet u don't have firmware for a CLC100
            • zoraldinho
              teacher-guide-expert-guru
              • Mar 2008
              • 5015
              #276
              Good one,ha ha.
              • Karasvas
                #277
                Sir can you email Canon IR3300 SST and firmware my email id is kara.svas@gmail.com
                • philip1davies
                  • Feb 2011
                  • 23
                  #278
                  I may have a set of old EPROMS
                  And I have still got uv eraser and and a copier
                  You supply your own EPROMs
                  • yourownfree
                    • Dec 2007
                    • 474
                    #279
                    sst is not something we can freely give. Also the firmware file for the 2800/3300 is about 250Mb, not something you can easily send in an email.This is something that has to be downloaded.
                    • igorbirokip
                      • 24
                      #280
                      ir c 2100 / EFi network color board A1 System or ISO IMG
                      Does someone has a system for IR C 2100 / 2105 network color * EFI board A1. in return, I have many sevice manuals and system software for the Canon. Thanks in advance igorbirokip@teol.net
                      • rurrijola
                        #281
                        HELLO
                        I need Canon service support toll to upload system and software for canon IR5800c , here is my email, ill really thank any help rurrijola@yahoo.com
                        • JustManuals
                          • Jan 2006
                          • 9838
                          #282
                          1st post and wants something. How surprising.
                          • teckat
                            • 16083
                            #283
                            They expect it server on a platter !!!!!!!
                            Don't Think So ~~~~~~~~~~~~~~~~~~~~~~
                            • CT Copier Repair
                              • Mar 2010
                              • 304
                              #284
                              its becoming a big problem on this site
                              all these people just dropping in and wanting
                              is it just me or do you not have to contribute
                              also isn't it illegal to send canon firmware out of the country?
                              i think i remember that from somewhere
                              Just venting
                              • rurrijola
                                #285
                                Sorry for that
