Canon service support tool
Knowledge and the will to learn is the first step , I can send u some information on the 3200, it is best to read and understand the workings of this printer.
You can start testing this 3200 HDD,
Have printer powered off
1.Hold down the 1 & 9 key, while still holding> down power up 3200
2.wait until u see the screen go into the download mode
3. u will see white blocks dropping on screen/ let go of the 1&9 key
4. wait about 30min. & see if it will complete this Defrag of the Hard Drive,
5. U may get lucky and have this fix your 602 issue.
6. If machine goes back to a 602 error code, u will have to buy or get a HDD somewhere.
hope this helps, check your mail later for the 3200 information
This is finish and now I have black screen with massage DOWNLOAD MODE what now ?Leave a comment:
If u need a 40gb-HDD for this model that is not an OEM from Canon,
u have to search the internet {google} for them . most will be used/refurbished.
Try these links below>>>
IBM IC35L040AVER07-0 -IC35L040AVER07-0 - Find great deals on IC35L040AVER07-0 at DealTime
IBM IC35L040AVVA07-0 -IC35L040AVVA07-0 - Find great deals on IC35L040AVVA07-0 at DealTime
SAMSUNG SP0411N -
Samsung SP0411N 40GB 7200rpm 2mb HDD ATA-133 Hard Drive - Reviews, Features, and Prices $18 - $32 at DealTime
Hitachi-HDS722540VLAT20 -Hitachi Deskstar 40 GB ATA-100 Hard Drive - Reviews, Features, and Prices $17 - $53 at DealTime
Seagate ST340014A -ST340014A Hard Drives - Save time and find great deals on Hard Drives at DealTime
Hitachi HDS728040PLAT20 -http://www.dealtime.com/HDS728040PLA...oducts?CLT=SCHLeave a comment:
Good, u may get lucky and have a working printer
if you want to set up printer for BLACK Copies only>>
Set Black as the Default Color
Answer :
Press the Auto Color Select Button on control panel:
1. Select Black
2. Select the Additional Function Button
3. Select The Copy Settings Button and go to the Second Screen
4. Press the Standard Settings Button
5. Select Store ( A message will come up asking you if you wish to store this setting.)
6. Select "Yes" Store in Memory
7. Press the Done Button
8. Press the Done Button again in order to go out of the Additional Function Screen
Tomorrow I bring about HDD
thanks for the instructions and wait for SST...Leave a comment:
Answer :
1. Select Black
