Canon Gp605: Error 202
  • xtraez
    • Jun 2008
    • 42
    First all, machine give error 100, so i do open the IP board and laser unit. Clean up everthing since there is dust on it. After clean up, put back as before.
    Turn on , machine initialize for a while, after 3-4 sec machine prompt error , all error light stay on.
    I do check at service mode, found this error error 202.
    My machine given error 202 at service mode,
    After reading through this forum, i do check on my machine found this :
    At my machine display << the PS1 ( Home position scanner sensor ) - no block is "1" , block "0">>.
    In this forum and service manual state : this sensor must be <<no block is "0" , block "1">>.
    Please help me..
  • brianSTX
    • 12
    E202
    Reinstall copyboard glass
    check operation of cpybrd glass sensor
    check for scanner movement
    check scanner home position sensor
    • xtraez
      • Jun 2008
      • 42
      Thank a lot Brain.. it working. I dont notice the copy glass sensor.
      • xtraez
        • Jun 2008
        • 42
        New Error Come Out E063
        Since the motor are remove out, where can i switch off the cleaning transfer mode.
        I found the text below. But it not apply to GP605, so please help me..
        more than likely you have broken the microswitch... here's a lil' tip, the unit runs the wire cleaners during startup and it is not detecting the HP of the T/S Corona Wire Cleaner... between you and me, the wire cleaners do not really do a whole lot to help or correct the image (don't tell cust. that, because engineers put that in to make them feel that they are doing useful maintenance), most techs in the field will just turn the check off in service mode... in service mode select the following Copier/Option/User/W-CLN and set it to a 0. I have seen guys just doing a PM on a unit, and get called back the next day because of the lil'swich... trust me, nothing makes customers feel reassured about their machine then when it throws a E-code the day after a PM... save yourself the time and turn it off.... but you didn't hear that from me...
        • Alan Aya
          Originally posted by xtraez
          It do apply to GP605. It is under BODY not USER.
          In the service mode >COPIER>OPTION>BODY>W-CLN, just turn it off will disable the auto wire cleaning mechanism.
          • xtraez
            • Jun 2008
            • 42
            Thanks Alan.. it great, thanks again for guiding me. it work on page three.
            • xtraez
              • Jun 2008
              • 42
              New error coming E100
              From service mode i check this data FOR ERROR E100:
              1. VL1M - 82 (SPEC FROM SERVICE MANUAL 62-82) --> GOOD
              2. VDM -405 (SPEC 432-452) --> NO GOOD, HOW TO ACHEIVE THIS SPEC.
              ..PLEASE HELP...
              • xtraez
                • Jun 2008
                • 42
                Error E100.... please help me..
                • davidj7
                  • 1107
                  check if the laser shutter door is open when you close the front door
                  • Alan Aya
                    Davidj7 is right, check the front door first, the laser shutter should open when close the front door.
                    Second posibility could be the Laser unit is faulty, check the value for LA-PWR-A & LA-PWR-B is it same as the value with the label attached on the laser unit. Can try do some slight adjustment to the LA-PWR-A & LA-PWR-B (increase/decrease the value, maybe it will help, temporary)
                    3rd coulr be the Image Processor board.
                    • xtraez
                      • Jun 2008
                      • 42
                      laser shutter ok... tq
                      • xtraez
                        • Jun 2008
                        • 42
                        i will try this method
                        • Canuck
                          Tech Specialist
                          • 1713
                          Make sure the beam detect pcb is clean.....really pay attention to the linkage that opens the shutter for the laser as previously stated...make sure actuator on door is ok
                          • xtraez
                            • Jun 2008
                            • 42
                            First of all... thanks for reply .. Canuck.
                            I do check the laser shutter, the door close, laser shutter open..
                            I'm try simulate by putting flash light infront of shutter and check throud, i found BD path area there is no obstruction.
                            Friend .. how to check the laser shooting light?.. i don't have any tools to measure it. Can laser been seen on naked eyes.. anybody tries before?
                            • mrfixit51
                              Lead Service Technician
                              • 1975
                              Don't look at laser with your good eye...
                              I pray you do not attempt to look at this laser, unless you happen to have a spare set of eyes lying around
