Canon clc 1180
  • Luther
    • May 2006
    • 682
    Canon clc 1180
    I have a code on this machine which Im not to familiar with, E072-0202 which i think has something to do with the transfer cleaning or polishing units,anyone familiar with this code or model, any help would be appreciated, thanks in advance
  • charm5496
    • 2387
    That code is the board and motor inside the transfer drum up top. Motor is held in by two screws that come out the front. I would replace them as a set as the motor over heats and then damages the board.
    • Luther
      • May 2006
      • 682
      Thanks already changed that motor and board..............not the problem
      • anothertech
        • 1762
        Check/Clean the interlock switches, when they get dirty inside they can drop some voltage sometimes resulting with this error.
