Canon NP 6050 drum unit removal
  • stupidmachines
    • Dec 2007
    • 14
    I have the great fortune to work on this relic, and I can not for the life of me find my old manual, probable trashed when we moved. If memory serves me correctly I have to get the developing unit to dis engage somehow. Anyone still have this info?
  • costd
    • Jan 2008
    • 409
    Open right side, remove screw holding cover (lower left as you are looking at it), unplug connector, pull developer out.
    They may be old, but most of the newer B/W machines disassemble the same way.
      • 23009
      Once you've got the developing unit out, you'll have to remove the toner hopper. There are a few screws and the drum retainer, lower the bed handle, then the rest of the imaging unit will slide right out.
      It makes a disconcerting noise when you slide out the imaging unit. The drum shaft is textured, and the ground inside makes the noise. The first time I thought for sure I had wrecked the drum. =^..^=
