need help on IR7105 with Saddle finisher V2
  • techsurp
    • Aug 2025
    Hi Folks, I need help on IR7105 with Saddle finisher V2 that we have just got in, it says "finisher cannot be used" but machine will still copy ok, I have been told i need to go into service mode to reset this, Can anyone please help me on how to get into the service mode on this machine. Thanks.
  • MrB
    • Nov 2009
    • 147
    Sounds like the machine is "Limited Function Mode"
    Goto Addition Functions {*)
    Common Settings
    Go down a few pages
    Tap on limited Functions Mode
    If it's ON, tap "OFF", then OK
    Then press the reset button a few times, back to normal screen
    Then REBOOT your device
    Fingers crossed, everything should be okay
    • techsurp
      Hi and thanks for the swift reply, I have tried that a few times and after each reboot the are back on again but still no joy.....any other ideas?
      • 20YRSEXP
        • Oct 2008
        • 281
        Try service mode Function>Clear>MMI and reboot.
        Is the glass half full or half empty? I say neither. The glass is obviously full, full of potential. The potential to hold more water or the potential to quench a thirst. Life is all about how you see it.
        • Herrmann
          • Jan 2006
          • 792
          Maybe, there is an error not shown on the screen....go into service mode, and look the error history for e5xxxx errors, then we can look further
          If sometimes you feel a little useless, offended and depressed always remember that you were once the fastest and most victorious sperm of hundreds of millions!
          • mtech
            • Mar 2007
            • 307
            You need to check for errors! I am sure there will be a finisher error. Address that error and your issues will be over.
            • SCREWTAPE
              East Coast Imaging
              • 3396
              Did you reset everything after disabling functions limited.
              Main unit then finisher. Finisher then main unit.
              Are there any other accessories, internal punch, pro punch, ETC.
              • techsurp
                Hi Guys and thankls for all your continued help....I have tried dissableing the saddler, punch and stappler and feeder as advised and done a re-boot, after reboot they are all back on again but it still says finisher can not be used so something is still amiss, at least the actual IR7105 is ok so i think i will put it up for sale for just the copier itself and just throw in the finisher with it.....thanks for the help anyway chaps....chris
                • Electrictoner
                  • 48
                  do complete shutdown
                  you have to wait the 5 minutes until it tells you to power down switch on side. you can't short cut and just turn off remember power off V-2 first then hold off button till you get please wait shutting down
                  Billy
                  • hemai2005
                    Professional Print
                    • 108
                    hi all
                    i faced this problem 2 day ago , solved and the causes for this problem flag paper sensor correct pos.
                    and before 1 year i faced same your problem and every thing is ok in this case but Fortunate the customer have another machine and i take board from the back of the finisher and problem solved
                    i will send you the name and no of this board
                    thanks
                    sigpic
                    Learned a lot will become an expert
                    • SCREWTAPE
                      East Coast Imaging
                      • 3396
                      Anything under limited functions should be off. There are two pages with options to limit under additonal functions>Common settings>limited functions mode.
                      Limited functions for the punch should be off as well
                      • teckat
                        • 16083
                        Check that Molex Connector at the copier end. Open the connector housing and check for broken wires or if the connector is unplugged or not fully engaged.
                        also check that both dip switches on Finisher Controller are set to ON !!!!!!!!!!!!!
                        • nivssluck
                          • May 2008
                          • 228
                          * 2&8 * Copier Option look for ACCP or something like that then under the Finisher change the value to 1.
                          • roho
                            • Mar 2009
                            • 844
                            just wondering if you are following the correct shut down/restart proceedure for that model. If the device and accesories aren't shut down in the proper order, the finisher may not be recognized.
                            • SCREWTAPE
                              East Coast Imaging
                              • 3396
                              This is irrelevant. If the ACCPST-D is set 0, hypothetically speaking, Paper would just crash upon delivery. The machine recognizes the finisher.
                              So this would not be the case.
                              Techsupp, the worst case scenario would be..
                              A bad fuse PCB, check continuity on fuses,
                              Or, a bad switching regulator or, bad finisher controller PCB.
                              You have not mention any E-codes from service mode. There must be a Error code associated with the message. What are the error codes, this will help guide you in the right direction.
