Error cde
  • 4raddoo
    Error cde
    Error code e000014-0000 appear on my canon IR3300 screen.How can I fix it
  • charm5496
    • 2387
    it is either the fixing unit or the fixing motor
    • teckat
      • 16083
      Check the fixing unit for binds
      -There may be a bind in the fixing unit that impedes the movement of the fixing motor.
      Check the fixing motor connector
      -Is the connector of the fixing motor connected?
      -NO: Connect the connector.
      Check the Main power supply PCB (also known as the Switching Regulator)
      -Is the drive voltage (24VDC) of the fixing motor supplied by the main power supply PCB present?
      -The Main power supply PCB (also known as the Switching Regulator) can be checked by checking for 24VDC on J202-3 (24VU1-S) and J202-4 (OVU1).
      -NO 24VDC: Replace the main power supply PCB.
      Check the Fixing motor (M4) and DC controller PCB
      -Press the Start key. Is the lock signal of the fixing motor present at the connector (J312) on the DC controller PCB?
      -Lock signal: J312-B4 (FSRM_LOCK*) Does the signal from the DC controller PCB change from 0 to about 5 V when the Start key is pressed?
      -YES: Replace the fixing motor.
      -NO: Replace the DC controller PCB.
      • mrfixit51
        Lead Service Technician
        • Oct 2008
        • 1975
        Most likely cause of E014 on this fuser is a clean roller that was allowed to be in the fuser too long. Thick deposits of toner build up on the roller, it deforms and wedges the pressure roller, causing too much of a bind, and thus,, the E014
        • davidj7
          • 1107
          If there voltage fluctuations then i used to get it
          a machine is only as good as your tech : source:screwtape ; the scary one
          • mrfixit51
            • Oct 2008
            • 1975
            E019 is waste toner error on this copier
            • teckat
              • 16083
              no !!!!!!!!!!!!!!!!
              • SCREWTAPE
                East Coast Imaging
                • 3396
                Originally posted by marc.lucas
                I stand corrected then. Is E014 watste toner full on another model or am I just going mad!?
                I think your going mad.
                E014 in every model is fixing motor related
                Maybe your confuse. The iR3100 pops a E013 for waste toner. Thats pretty close to E014.
                Maybe you need a vacation.. LOL
                • Brian8506
                  • 1664
                  I just had it on another dealers customer. The cleaning roller was at 435%. You wouldn't believe the crust buildup. It was enough to stop the motor.Check and replace the cleaning roller like Mrfixit51 says.
