iR5000
  • waffu22
    • Jun 2009
    • 95
    iR5000
    Hi
    I have canon iR5000 which when i make copies through glass the output of the copy is half of the paper is clear, and half is purely black. This was happen when error 100 - 001 occurred.
  • shazza
    • Nov 2009
    • 96
    Hi,
    Got to be laser related check shutter and also all corona asy.
    Shazza
      • 23009
      E100 is a Beam Detect error. Your laser is dying. =^..^=
      • montana
        • Aug 2008
        • 392
        hi...the system error 100-001 is related to the laser unit malfunction..so you have to check any obstacles in laser unit
        or check the shutter movement..
        i hope it's help
        • teckat
          • 16083
          Originally posted by waffu22
          Hi
          ???? did u service this printer before errors or copy q issue ??
          ***Half Clear/ Half Black glass copies only= is a scanner issue check below:
          If your issue is with glass copies only try this: place paper on glass Lift cover & Look to see if the scan lamp stays on thru the scan ?? or try next :
          Place the original on the glass, and completely covering the platen glass with white paper, close the feeder and make a copy. If the shadow still appears. The problem may be with the mirror alignment.
          • waffu22
            • Jun 2009
            • 95
            You've mention with the mirror allignment. Is that the mirror inside of the scanner? Can u please give me a diagram?
            Thanks.
            • Brian8506
              • 1665
              Check the reflector by the scan lamp. If it only happens when copying, this may be bent. I've had schools put a book on the glass and press down and when it scans the reflector gets bent on one side.
              • teckat
                • 16083
                that's a good point !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
                • mrfixit51
                  Lead Service Technician
                  • Oct 2008
                  • 1975
                  Lets get back on track here,, the E100 is the real issue here I believe,,, the scan lamp and reflectors have nothing to do with the E100. iR5000's have been out there a really long time,, sounds like your laser is showing it's age. Run Test prints from service mode to rule out the top end of the copier, this will cut your problem in half...
                  Also keep in mind that this copier's laser erases,, it does not write to black, it writes to white...
                  • waffu22
                    • Jun 2009
                    • 95
                    I thank you all for the reply. I did not use my machine for 3 days because a lot of things i did. And this day I open it and a lucky day my machine works fine and the copy is now OK. I think they need rest like people.(-_-)
                    Thnanks.
                      • 23009
                      Does this machine get cold, 0 celsius or less? I have taken a cold machine from the car, and installed it in a warm humid environment, and gotten laser codes. It's because the polygon mirror or beam detect mirror have a coating of condensation, diffusing the laser beam.
                      Take my word for it. Your laser didn't heal itself. You can fix it now or wait until next week when it fails entirely. It's up to you. =^..^=
                      • waffu22
                        • Jun 2009
                        • 95
                        Here in the Philippines is summer season now.
                        This machine starts with error 0061. And what I gonna do is just clean the transfer assembly and the error gone. After a few minute error 100 occurred. And according to manual its the laser faulty. So i just leaved it. And when I opened in the next day the problem gone.
                        • SCREWTAPE
                          East Coast Imaging
                          • 3396
                          I couldn't say it better myself!
                          E061, E100, the laser is going bad. Replace it when you can.
