ir1023 - Unable to get to Webinterface
  • seantydingco
    • Sep 2008
    • 20
    I am having an issue getting to a customers UI on their ir1023. I tried Mozilla firefox and it worked for a few minutes and then just timed out like Internet Explorer(Http 400 bad request) error comes back on IE.
    I checke to make sure the Remote UI feature was turned on and rebooted the copier a few times, and still same result.
    Has anyone had an experience with this. I was scanning through the Canon Esupport site, and still have not found anything yet.
    The customer said they have had this issue for almost a year, so we updated firmware and still not avial.
    Sean
  • anothertech
    • 1768
    Set the RUI to On, under Additional Functions, System Settings, Remote UI. (make sure that HTTP is also enable and no IP address ranges are set for HTTP access)
    • teckat
      • 16083
      Correct version of RUI firmware must be flashed onto the copier. A specific version of the RUI firmware is required for each individual version of system software.
      Flash the copier with the correct version of RUI firmware. with User Support Tool
      Be sure to enable HTTP and RUI on the copier.
      Be sure to enable "Dedicated Port" on the copier.
      Type in IP address of the imageRUNNER in the browser address bar.
      When one of the Dept. ID, SDL, or SSO authentication functions is enabled on the copier the RUI is also restricted to authorized users
      MEAP Enabled Devices, please make sure that the proper MEAP version in Service Mode/Copier/Display/Version is also installed. If everything fails, perform a Clear MMI. Also note that on MEAP enabled devices, USE HTTP under TCP/IP Settings and USE HTTP under MEAP Settings must be ON.
      • seantydingco
        • Sep 2008
        • 20
        Thanks folks, I will test these out. I was going to do a wipe and reset to bring back to factory defaults, but I will do all suggestions as well.
        • mrfixit51
          Lead Service Technician
          • Oct 2008
          • 1975
          A clean install of complete system software package should resolve it...
          • SCREWTAPE
            East Coast Imaging
            • 3396
            Have you tried pinging the 1023 to verified that your network connection is okay? Just a thought.
            • seantydingco
              • Sep 2008
              • 20
              Yes the copier has responded to pings, and it prints out just fine.
              The problem is the webinterface does not come up in IE. It works for a few seconds on Firefox, but then it also loses it afterwards.
              We are going to do an update first and move from there.
              Thanks for all those who have helped.
              Sean
              • SCREWTAPE
                East Coast Imaging
                • 3396
                Have you connected directly to the 1023 with a laptop.
                • vidarb
                  • Mar 2010
                  • 25
                  I am also having this problem, and the customer can not scan. Print works fine. Will try to upgrade today and see what happens.
                  Even a broken clock is right twice a day.
                  • vidarb
                    • Mar 2010
                    • 25
                    Haha, loaded software v.63.01 with SSt 4.23.
                    Everything was going as planned.
                    Powered of and on the machine and it bricked!
                    Dont know what went wrong but now i probably need to replace the image processor PCB.
                    • SCREWTAPE
                      East Coast Imaging
                      • 3396
                      Sucks to be you!
                      Before you upgraded, was the machine working, besides the scanning issue.
                      Do you have the earlier firmware you upgraded from. Try downgrading to see if its the firmware.
                      • teckat
                        • 16083
                        This model has procedures u need to follow when upgrading FIRMWARE from, different Versions60/63/65.
                        if not followed u will have issues.
                        if u revert to an older Ver.follow>
                        On Ver.60.03 u need to follow this first:
                        Upgrade Procedures:
                        1. [1] Using the Service Support Tool, upgrade the BootROM to ver.60.03
                        Note: Before using System Software v60.03, make sure to install the BootROM ver.60.03 first.
                        2. Make sure to turn OFF and ON the main power between each download.
                        3. Using Service Support Tool, install System Software ver.60.03.
                        4. Turn off and on the device power.
                        Upgrading When the Optional ROM is installed:
                        When installing the following option, the optional ROM (32MB) included in the package must be installed.
                        Installation of the optional ROM enables the controller to operate on the firmware of the optional ROM.
                        Therefore, when installing the optional ROM, be sure to check the versions of the main controller, Boot ROM,
                        and optional ROM, and when the versions do not match, upgrade the version using the Service Support Tool to
                        match them.
                        Options in which the optional ROM is included in the package:
                        - PCL Printer Kit-M1
                        Importing/Exporting User Data
                        - If using service mode (SSSW>SYSTEM SW>SW03), connect the USB cable.
                        - If using the RUI (set initial settings>import/export), connect the network cable.
                        Make sure the NETWORK settings are shown in the Users Data List + in SPEC REPORT it should list NETWORK ON
                        If not make sure the interface connectors are seated firm between LAN BOARD and the Main Board
                        • seantydingco
                          • Sep 2008
                          • 20
                          Update for me on this issue guys. We tried everything but kept getting the same error, so we upgrade the firmware and Walla!!! Issue resovled. At least for this particular situation.
                          Sean
                          • teckat
                            • 16083
                            Sean
                            • mrfixit51
                              • Oct 2008
                              • 1975
                              I guess the old fart was right...
                              Glad you've resolved it!!
