Tips on canon models
  • Canuck
    Tech Specialist
    • 1713
    #46
    One-way clutches....yeah Canons favorite. Xeroxs very rarely use them. I clean the shaft with alcohol,replace it if its scored. I've actually put e-rings on the shafts as spacers as a temp fix...this way clutch rollers grab different area of shaft. Otherwise clean the shaft and the inside of the oneway with alcohol. Then a drop of high quality turbine oil on the shaft and 2 or 3 drops on the rollers in the clutch. The rollers in the oneway must be clean and oiled for the clutch to work properly and consistently. Sewing machine oil works good also....doesnt gum up. Triflow works too but gets gummy. I never use a grease type of lube...there are springs inside the clutch
    • Penvy
      • Oct 2008
      • 237
      #47
      You reminded me that Gun oil and sewing mach oil are great.
      P
      BTW the torrington 1 way clutches have a plastic bearing guide inside,
      what happens on the shaft that the bearing has a buildup that solvent and(not kidding)
      500-1000 grit sand paper will do wonders.
      Same for the wrap spring type(but get the inside of the spring too) if your in a fix dont have the part (2 min repair)
      P
      • montana
        • Aug 2008
        • 393
        #48
        hi mr screwtape.thanks for usefull tips...i want to ask you about problem that iam facing these days with canon Ir2016j..every time i replaced the fixing film it is working a few days then oo7 appears when i check the film i found it broken from the left side
        not the speed sensor side..this issue occured 3 times..last time i replced the fixing assembly not the whole unit.i mean (the heat element coated with fixing film)it works about one month then 007 again ...the film broken at the same side..
        ever you seen this my dear?thanks and execuse my english.....
        • xcopytech
          • Aug 2006
          • 1792
          #49
          Canuck and mrfixit51 can you post here that TP09 239.
          Thanks in advance.
          • jshafer
            #50
            I have a canon IR1023 it says Download STANDBY Its not normally hooked into the network, last week this same thing happened and I plugged a ethernet cable into it and plugged it into my router and it went away... same thing happened again but this time when I plugged in the cable into the network nothing is happening... ANYONE please help with this is there away to do a HARD RESET on the entire machine. I can't press any button
            • teckat
              • 16083
              #51
              Thanks in advance.
              Measure to Prevent Displacement, Breakage of the Fixing Film and E007-0000
              imageRUNNER 3245 Series Procedure for Adjusting the Fixing Nip Adjustment Screw
              Affected:imageRUNNER 3245 DHJ00001 ~ DHJ03522
              imageRUNNER 3245i DHK00001 ~ DHK04323
              -Open the right door assembly.
              -Open the jam handling cover at the fixing assembly.
              -Look into the leg of the front adjustment screw
              -Fit the end of a ruler onto the plain surface of the metal plate in the
              front side and measure the length of the front adjust screw.
              It is difficult to measure the length of the rear adjustment screw leg,
              so visually compare it with the length of front adjustment screw leg
              or use a piece of paper with a 10mm mark.
              ir3235/ir3245=8 to 9.5mm
              ir3225=6 to 7mm
              -If the measurements are not within the standard above, remove the
              fixing assembly from the copier.
              When re-adjusting the front adjustment screw, turn it with long nose
              pliers or T15 Torx screwdriver so that the screw length of its leg falls
              within the standards below.
              ir3225=6 to 7mm
              -When re-adjusting the rear adjustment screw, turn it with long nose
              pliers or T15 Torx screwdriver so that the length of its leg falls within
              the standard above.
              - After re-adjustments, return the fixing assembly to the copier and
              execute the following service mode to check the nip pressure:
              COPIER> FUNCTION> FIXING> NIP> CHK
              Standards:
              iR3235/3245s: 7.6 to 10.6mm
              iR3225s: 4.0 to 6.0mm
              imageRUNNER 3245 Procedure to check the alignment of the Fixing Assembly
              - Open the right door assembly.
              -Remove the fixing assembly so that the
              left and right side alignment plates are
              viewable as shown in the pink squares
              in the left photos.
              -Locate the alignment plate shown to the
              left and verify if the bosses exists
              nearest to the center of the slotted holes
              as possible. If they are not, adjust the
              position of the plate.
              - Perform the same adjustment
              for the plate shown to the left
              and verify the bosses of the
              plate exist in the correct
              position. If not, adjust the
              • Canuck
                Tech Specialist
                • 1713
                #52
                Thanks Teckat....mine is a PDF from Canon
                • Raoufselwaness
                  Expert
                  • Nov 2008
                  • 75
                  #53
                  Thanks Teckat for your precise replay.
                  I have a problem with IR 4600 it gives always E61 every day morning with the 1st. copy, and then maybe or maybe not give some gray copies and then works fine till next day
                  i replaced charge corona, Potential sensor,High-voltage PCB one by one and still have same error code.
                  hope any one can help
                  THANKS
                  • Canuck
                    Tech Specialist
                    • 1713
                    #54
                    what is an ir4600?
                    • Raoufselwaness
                      Expert
                      • Nov 2008
                      • 75
                      #55
                      Originally posted by Canuck
                      what is an ir4600?
                      hi
                      it is same as ir 5000/6000 m/c
                      • Canuck
                        Tech Specialist
                        • 1713
                        #56
                        If it is generating E-061...yes...potential control problem...laser shutter possibly.... i'm not sure what model this is????? On 8500s and 105s dirty drum heater contacts will give you background first thing in the morning then disappear...fuser eventually warms drum up
                        • Raoufselwaness
                          Expert
                          • Nov 2008
                          • 75
                          #57
                          dear canuk;
                          i will try your idea 1st. thing tomorrow morning hope it works.
                          the IR4600 is same as IR6000/5000 m/c's in every thing i use the same p/n and manuals for this model.
                          it is imported from UK to Egypt -used- and sold as is. it uses same toner, developer tank, hopper, drum,fuser unit
                          same feeder, same finisher.
                          thanks a lote
                          • teckat
                            • 16083
                            #58
                            Originally posted by Raoufselwaness
                            dear canuk;
                            thanks a lote
                            Keep on all night/ go back and turn off/ and on when u get there- see if error pops up
                            old tech pub> E061, early morning only.
                            imageRUNNER was turned off/on, it worked fine until the next morning. If the unit was turned off overnight, it would warm up correctly. The bearings of the laser unit were causing it not to speed up correctly, causing the error E061 message. Laser unit was replaced.
                            • Canuck
                              Tech Specialist
                              • 1713
                              #59
                              Yes i would be checking out the laser shutter operation. The actuator is on the front door...as per teckats' posting...check for e110 error logged in error history
                              • Raoufselwaness
                                Expert
                                • Nov 2008
                                • 75
                                #60
                                dear friends;
                                thanks for attention, and it is actually unplugged completely from mains supply over night.
                                Is this can cause the problem?????????
