ir 3300
  • CITY STAR
    • Aug 2025
    ir 3300
    pls help me
    We are using Canon 3300 machine. I have the following problem in this machine.. when switch on the power L.e.d light blink and machine switched off, and also that the same time there is power light being blinked and switched off. I have checked the two power supply smps, but its also working properly let you guide me to identify the problem with this.
  • songela
    • Mar 2008
    • 216
    First of all, I believe we need to solve the way you present the problem. It could be a minor problem but you need someone to help you describe it from a more technical point of view. It seems as if the machine switches off by Auto Shut-off action, if that is the case, you need to note what error code message is displayed before this happens. Regards!
    • CITY STAR
      Real Problem
      Thanks for your reply The real problem is Machine power tripped automatically when its starts....There is no display also coming to know the error code.
      • smiley
        • Aug 2008
        • 615
        try to open the front cover and let the machine to bootup and the error will display and lets us know the error code im sure its in the fixing unit problem.
        there is no glory without sacrifice
        • montana
          • Aug 2008
          • 392
          hi...on back side of the machine there is a leakage breaker switch it cuts power in response to error..
          • mrfixit51
            Lead Service Technician
            • Oct 2008
            • 1975
            But it will not reset itself, the person did not indicate this was being tripped. Normally AC issues are indicated by the tripping on/off main switch...
            • teckat
              • 16083
              First ?? Are u a service tech or end user. Were u working on machine before issue.
              open front door with no interlock /turn on PWR/ get into service mode check error log/make note
              Perform an error clear. COPIER>FUNCTION>CLEAR>ERROR CLEAR in service mode
              • roho
                • Mar 2009
                • 844
                Sounds like a fuser error-you need to clear error in service mode-reboot!
                • teckat
                  • 16083
                  Fuser errors need to be investigated, before clearing the E code/ this person may be an end user !!!!
                  • SCREWTAPE
                    East Coast Imaging
                    • 3396
                    In most cases the cause of a machine powering OFF is an AC circut open or shorted. At what point did all this happen? who was doing what? If you are a end user call a professional. To rule out what's going on, your gonna have to check voltage signals from AC components. Check your Fixing unit first.
                    • CITY STAR
                      thank you
                      The problem is in fixing unit the I.C shot in the p.c.b.....thanks for the guidence to solve the problem....
