Canon CLC3900, Error message "Check power and cable"
  • williamsluu
    • Mar 2010
    • 11
    Hi,
    Please help me with the following Error message "Check power and cable", copier won't get pass this message. Already check all cables, all good, I think.
    William
  • SCREWTAPE
    East Coast Imaging
    • 3396
    Originally posted by williamsluu
    Hi,
    William
    Where are you seeing this error. Is it on the fiery??
    • teckat
      • 16083
      Hi,
      William
      Check Power and Cable Message
      any colorPASS model connected to a CLC3900 / CLC3900+ / CLC5000 / CLC5000+ / CLC4000 / CLC5100
      If the colorPASS interface cable is connected, or disconnected, with the copier power on it is possible that FU5602 may be blown on the copier fuse pcb. This fuse protects the 5vdc fed to the copier interface pcb through connector J5617 pins 3 and 4 on the fuse pcb. Check these pins for 5vdc, if it is missing replace the fuse pcb on the copier, part number FG3-1397-000.
      / make sure when u power up machine the scanner is not stuck and moves under white plate to read bar code- scanner bar code may be soiled, scratched or damaged
      if Check Power and Cable" Message is displayed on the Control Panel.
      First, make sure all of the Accessories for the machine are plugged in properly to each other and to the machine. With good connections, proper voltage and communication signals should be present. The voltage and signals may need to be checked with a meter
